Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel, Is this a normal looking rod? And how the heck do I get the pin out? |
DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
mlindner |
Jan 19 2020, 06:26 AM
Senior Member Group: Members Posts: 1,530 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
DRPHIL914 |
Jan 19 2020, 06:01 PM
I appreciate the offer, if I mess anything up I will get in touch. For now the plan when I get back tomorrow is to attempt pressing the pin thru, and reassembly with either bronze or stock bushings I have both. I forgot to order new cone screws so I am hoping some red thread lock would be ok. Mark is right no reason to reinvent the wheel here- I guess I am curious about that one aftermarket coupling, and feel like it could be used if the stock one were damaged in removal. You’d still use stock bar but no sense spending $$ where I don’t need to. Next issue is to fix oil leak I am getting from the oil pressure relief valve plug- I am otherwise leak free. |
Lo-Fi Version | Time is now: 11th June 2024 - 10:30 AM |
