| JamesM |
Jan 20 2020, 01:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,182 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Re assembling a 74 LE Bee from a pile of parts and found the that intake plenum that I got with its original motor is the later style that doesn't use the "F" vacuum connector/has no port of the crank case vent.
My instinct is telling me that this is the wrong part, but i wanted to confirm with another LE owner as to the intake plenum/ crank case vent system used on their LEs. Having noticed other differences between the LE and my earlier 74 car I just want to be absolutely sure before I go and prep another plenum to install. |
JeffBowlsby Its the standard 2.0L plenum...it requires the F c... Jan 20 2020, 02:21 PM
JamesM
Its the standard 2.0L plenum...it requires the F ... Jan 20 2020, 03:40 PM
Mikey914 Is this what you are looking for?
https://900desi... Jan 20 2020, 04:28 PM
JamesM
https://900des... Jan 20 2020, 05:06 PM
914Sixer Easy spot, the one on the left is a 75-76 because ... Jan 20 2020, 05:28 PM
JamesM
Easy spot, the one on the left is a 75-76 because... Jan 21 2020, 09:32 AM
914Sixer 70-74 uses a single pole switch. Jan 21 2020, 10:35 AM
JamesM
Correct. I h... Jan 23 2020, 10:25 AM
Mikey914 We have an unmolested LE Bumblebee, I will have to... Jan 21 2020, 12:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 12:24 AM |
