> Is there a "how to.." for crank measurement, and bearing verification?
malcolm2
post Dec 16 2019, 11:07 PM
I am gonna make a 2 liter from my 1.8. So I have a refreshed 71mm crank that I have been told has been ground to -0.010.
I measured as best as I can with a digital mic and got about 59.66 on the mains and 49.65 on the rod journals.
Where can I find the STD specs and ranges ? were they 60 and 50, respectively?
Since I know nothing about this crank, how can I verify the 71 mm measurement?
malcolm2
post Jan 21 2020, 08:30 AM
Rod Balancing, End-to-end. I also wondered how in the hell do you balance END-TO-END.
I found this 20 minute video (balance at 6 minutes) where he hangs one end on a nail and puts the other end on the scale.... weighs each rod and compares, removes material, repeats....
is that the way to do it? Good way, Bad Way???
This link and the embedded vid starts at 6 minutes.
https://youtu.be/U3IXSywgTnM?t=386
https://www.youtube.com/watch?v=U3IXSywgTnM?t=386
malcolm2   Is there a "how to.." for crank measurement   Dec 16 2019, 11:07 PM
Superhawk996   @malcolm2 My understanding is that this crank th...   Dec 17 2019, 06:17 AM
malcolm2   YES, It seems that @jtprettyman has passed it on...   Dec 17 2019, 08:46 AM
malcolm2   How about the 71mm measurement? Not that it matte...   Dec 17 2019, 08:51 AM
Superhawk996   How about the 71mm measurement? Not that it matt...   Dec 17 2019, 02:13 PM
Mark Henry   How about the 71mm measurement? Not that it mat...   Dec 17 2019, 11:26 PM
Mark Henry   I only use STD cranks or standard (under) cranks I...   Dec 17 2019, 09:24 AM
malcolm2   I only use STD cranks or standard (under) cranks ...   Dec 17 2019, 09:48 AM
Superhawk996   Also for what it’s worth, I provided this crank ...   Dec 17 2019, 02:34 PM
malcolm2   OK it passed the hammer test. very high pitched t...   Dec 17 2019, 06:30 PM
Superhawk996   With my method of measuring last night, I got a ...   Dec 18 2019, 08:53 AM
malcolm2   With my method of measuring last night, I got a...   Dec 18 2019, 10:03 AM
Superhawk996   Thanks for your input. I certainly hope you don...   Dec 18 2019, 02:58 PM
malcolm2   OK, maybe not the super duper accurate tools but I...   Dec 21 2019, 02:47 PM
Superhawk996   OK, maybe not the super duper accurate tools but ...   Dec 21 2019, 07:36 PM
Mark Henry   Sounds like a lot. If you're right about #4 yo...   Dec 21 2019, 03:24 PM
malcolm2   Your rods should at least have the big ends done....   Jan 20 2020, 08:59 AM
Superhawk996   So question 1: how do you "DO" the rod...   Jan 20 2020, 12:41 PM
malcolm2   Both micrometers were checked prior to the last me...   Dec 23 2019, 10:08 AM
Superhawk996   Both micrometers were checked prior to the last m...   Dec 23 2019, 10:34 AM
malcolm2   3) For hobbyists like myself, Plastigage can ser...   Dec 23 2019, 10:44 AM
malcolm2   UPDATE>>>>> Todd is the Director o...   Jan 14 2020, 08:38 PM
Superhawk996   Rod measurements align a whole lot closer to what ...   Jan 15 2020, 06:00 AM
jtprettyman   @Superhawk996 Yes, these were done with a very n...   Jan 15 2020, 08:58 AM
malcolm2   Rod Balancing, End-to-end. I also wondered how in...   Jan 21 2020, 08:30 AM
- Lo-Fi Version Time is now: 15th September 2026 - 10:24 AM
