Trailing Arm Spherical Bearing |
yeahmag |
Jan 21 2020, 03:25 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
It seems to me that the trailing arms are ripe for a spherical bearing mod. The way the rear toe is set leaves much to be desired, even with (if not more) with Delrin/Teflon bushings.
Has anyone tried to modify the inner ears to allow for a spherical bearing? |
yeahmag |
Jan 21 2020, 04:55 PM
Very cool! Is the new rod running through the trailing arm fixed in someway to the arm itself?
jd74914 |
Jan 21 2020, 10:19 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Very cool! Is the new rod running through the trailing arm fixed in someway to the arm itself? It’s not quite like that in real life. The tube running through the middle is representative of the trailing arm tube with the rolled lips removed. The other parts are then welded into an assembly for each side which was then pressed into the trailing arm and TIG welded around the perimeter. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:01 PM |
