motorvated |
Member ![]() ![]() Group: Members Posts: 282 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains ![]() |
I'm in the process of re-assembling the top end of my stock 2.0 liter four, and I have measured deck heights as follows:
#1 - 0.036 #2 - 0.029 #3 - 0.037 #4 - 0.035 These measurements are with the cylinder base sealing rings in place and the cylinders torqued down snugly and measured with a dial gauge. To me it seems as if I need to add a shim to the bottom of cylinder #2 approx. 0.050 - 0.080 to increase its deck height to within the range of the others. I have a couple of used 0.080 shims, one of which I could add to cylinder #2 to bring it up to 0.037. I have a couple of questions about this. First, how much variance is permissible between the measurements? If the deck heights are all within 0.002 of one another, is that Ok or do they need to be exactly the same. Second, can I re-use one of my 0.080 shims or should I source a new one. And third, do I place the shim on top of the cylinder sealing ring, beneath it, or doesn't it matter. I was planning on putting it on top of the sealing ring. Thanks in advance for your advice. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,314 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 05:36 PM |
