Friday, 19 September 2025
> Rod Balancing DIY?, end-to end
malcolm2
post Jan 23 2020, 08:37 AM
Rod Balancing, End-to-end. I also wondered how in the hell do you balance END-TO-END.
I found this 20 minute video (balance at 6 minutes) where he hangs one end on a nail and puts the other end on the scale.... weighs each rod and compares, removes material, repeats....
is that the way to do it? Good way, Bad Way???
This link and the embedded vid starts at 6 minutes.
https://youtu.be/U3IXSywgTnM?t=386
https://www.youtube.com/watch?v=U3IXSywgTnM?t=389
gereed75
post Jan 23 2020, 09:19 AM
When rebuilding my motor I tried very hard to do this including building a DIY balance rig. I could never get consistent weights that I trusted. I ended just balancing overall weight.
Not saying it can’t be done. If you look at the geometry a small amount of variation in how the rod sits in the rig will effect the weights, especially in the gram range.
Maybe someone can chime in with better results. Good luck.
- Lo-Fi Version Time is now: 18th September 2025 - 06:05 PM
