malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
Rod Balancing, End-to-end. I also wondered how in the hell do you balance END-TO-END.
I found this 20 minute video (balance at 6 minutes) where he hangs one end on a nail and puts the other end on the scale.... weighs each rod and compares, removes material, repeats.... is that the way to do it? Good way, Bad Way??? This link and the embedded vid starts at 6 minutes. https://youtu.be/U3IXSywgTnM?t=386 https://www.youtube.com/watch?v=U3IXSywgTnM?t=389 |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,388 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
When rebuilding my motor I tried very hard to do this including building a DIY balance rig. I could never get consistent weights that I trusted. I ended just balancing overall weight.
Not saying it can’t be done. If you look at the geometry a small amount of variation in how the rod sits in the rig will effect the weights, especially in the gram range. Maybe someone can chime in with better results. Good luck. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
When rebuilding my motor I tried very hard to do this including building a DIY balance rig. I could never get consistent weights that I trusted. I ended just balancing overall weight. Not saying it can’t be done. If you look at the geometry a small amount of variation in how the rod sits in the rig will effect the weights, especially in the gram range. Maybe someone can chime in with better results. Good luck. I tried the end to end also and could not get consistent readings, so just balanced overall weight. I matched pistons & wrist pins also and had access to a lathe so put small chamfers in a couple pin end ID's to get needed weights. |
Lo-Fi Version | Time is now: 18th September 2025 - 07:31 PM |
