Thursday, 11 September 2025 |
Daryl32 |
Member ![]() ![]() Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California ![]() |
So the refurbish for the 73 914 with Chevy 350 is now at the "What is this Mess?" Stage
Wiring in front bonnet area looks great - but once it goes through the "fire wall?" not sure what you call a front bulkhead? The wiring really takes a turn for the worse. The owner got a new to the car complete harness with it. It is a used harness that was removed from another car pretty much intact. The only real issue with it, is that some of the wires were cut with a cut off wheel. The area is where it came through the rear bulkhead. Plans are to use the 12 wire plug wires for the engine and gauges, some for what they are for. Wondering what others have done? Any help will be gratefully accepted. (IMG:style_emoticons/default/cheer.gif) I found wires in the car that went no where just attached and cut at both ends. Some pictures of the wiring: ![]() ![]() ![]() ![]() After new used harness was unwrapped and inspected, I rolled it up and set it on the floor of the passenger side of the car. Went into the house and had a medium old guy panic attack. (IMG:style_emoticons/default/confused24.gif) ![]() A couple of weeks later I started to tackle the new harness - laid it out of the table and had at it. I made a 4x8 table out of a sheet of plywood and covered it with cardboard, then laid the harness out for inspection. I started tracing wires to see where they went and inspecting for cuts or bare spots. I removed the factory fuse panel as the car has a bigger blade fuse style panel in it. ![]() ![]() ![]() |
Daryl32 |
Question : What tach are you running - or can the stock one be revised to work with a V8?
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,921 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Question : What tach are you running - or can the stock one be revised to work with a V8? You can use the 4cyl tach with an Ashlock Tach-adapt,you can buy them from Bob direct,great guy helped me setup my whole ignition or you can buy from Pelican parts. Make sure your tach is good however as the tach-adaptor won't fix a bad one. You have some work ahead of you but you will get there...good work so far,the Deutsch plugs are great,I used them on my ignition system,I also have some to fit on my gauges also. Good luck. |
Daryl32 |
You can use the 4cyl tach with an Ashlock Tach-adapt,you can buy them from Bob direct,great guy helped me setup my whole ignition or you can buy from Pelican parts. Make sure your tach is good however as the tach-adaptor won't fix a bad one. You have some work ahead of you but you will get there...good work so far,the Deutsch plugs are great,I used them on my ignition system,I also have some to fit on my gauges also. Good luck. Thank you so much, I will reach out to Bob. Owner says tach worked to 3,500 rpm and then back off - it did go in and out but 3,500 was it's max. I need to look up behind the tach and trace the wires, to see if anything is attached. |
Lo-Fi Version | Time is now: 11th September 2025 - 12:08 PM |
