> Working on refurbishing used wire harness, Refurbishing complete harness for 73 914-V8 project
Daryl32
post Jan 24 2020, 10:02 AM
So the refurbish for the 73 914 with Chevy 350 is now at the "What is this Mess?" Stage
Wiring in front bonnet area looks great - but once it goes through the "fire wall?" not sure what you call a front bulkhead? The wiring really takes a turn for the worse.
The owner got a new to the car complete harness with it. It is a used harness that was removed from another car pretty much intact. The only real issue with it, is that some of the wires were cut with a cut off wheel. The area is where it came through the rear bulkhead.
Plans are to use the 12 wire plug wires for the engine and gauges, some for what they are for.
Wondering what others have done? Any help will be gratefully accepted. (IMG:style_emoticons/default/cheer.gif)
I found wires in the car that went no where just attached and cut at both ends.
Some pictures of the wiring:
After new used harness was unwrapped and inspected, I rolled it up and set it on the floor of the passenger side of the car. Went into the house and had a medium old guy panic attack. (IMG:style_emoticons/default/confused24.gif)
A couple of weeks later I started to tackle the new harness - laid it out of the table and had at it.
I made a 4x8 table out of a sheet of plywood and covered it with cardboard, then laid the harness out for inspection. I started tracing wires to see where they went and inspecting for cuts or bare spots. I removed the factory fuse panel as the car has a bigger blade fuse style panel in it.
Daryl32
post Jan 24 2020, 12:41 PM
Dick the car was gutted of it's wiring 10 years or so ago - and the new old harness did not come with an engine bay relay panel. I may make one if needed, still working all this out.
Still trying to work out what relays at the engine a 350 really needs. None of my old Chevys ever had - have any.
Did you use any inline fuses for new things?
One of my older cars.
DickSteinkamp
post Jan 24 2020, 04:14 PM
QUOTE(Daryl32 @ Jan 24 2020, 10:41 AM) *
I don't think the engine needs any relays, but other devices will and did with the stock wiring.
The only new things for me were the electric choke and the cooling fans. I in line fused these.
Daryl32   Working on refurbishing used wire harness   Jan 24 2020, 10:02 AM
Daryl32   Some more pictures of the refurbish of the better ...   Jan 24 2020, 10:12 AM
DickSteinkamp   I was lucky enough with my V8 conversion wiring th...   Jan 24 2020, 11:34 AM
Daryl32   In your case, you may have to get more creative...   Jan 24 2020, 12:33 PM
ValcoOscar   :beer2: Another SoCal guy. :DRUNK: What city...   Jan 24 2020, 11:44 AM
Daryl32   :beer2: Another SoCal guy. :DRUNK: What cit...   Jan 24 2020, 12:34 PM
Daryl32   Question : What tach are you running - or can the ...   Jan 24 2020, 12:37 PM
porschetub   Question : What tach are you running - or can the...   Jan 24 2020, 01:04 PM
Daryl32   You can use the 4cyl tach with an Ashlock Tach-a...   Jan 24 2020, 01:13 PM
porschetub   Question : What tach are you running - or can the...   Jan 24 2020, 03:17 PM
porschetub   Question : What tach are you running - or can th...   Jan 25 2020, 12:52 AM
Daryl32   Dick the car was gutted of it's wiring 10 year...   Jan 24 2020, 12:41 PM
DickSteinkamp   Still trying to work out what relays at the eng...   Jan 24 2020, 04:14 PM
Daryl32   I don't think the engine needs any relays, b...   Jan 25 2020, 09:25 AM
Andyrew   Dick the car was gutted of it's wiring 10 yea...   Jan 25 2020, 01:29 AM
DickSteinkamp   Relay boards are available either used or rebuilt....   Jan 24 2020, 03:08 PM
DickSteinkamp   One more thought. The motor revs up so quickly wi...   Jan 24 2020, 04:16 PM
Daryl32   Thank you all for your help! I did some work...   Jan 25 2020, 09:21 AM
DickSteinkamp   Wiring diagram   Jan 25 2020, 10:26 AM
Daryl32   Wiring diagram thank you Dick! Been searchi...   Jan 25 2020, 11:23 AM
Daryl32   OK yet another question. The car is a 1973 2.0 or...   Jan 25 2020, 11:32 AM
- Lo-Fi Version Time is now: 3rd September 2025 - 08:40 PM
