| jrblackbox |
Jan 25 2020, 07:01 AM
Member ![]() ![]() Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None
Ok, so I changed out the starter in my 6 with another starter I had collecting dust. Now upon turning the key there is a "delay" of a second or 2 before the car turns over. So when I turn the key I can hear the fuel pump come on, then the delay, then the car will crank. did i put the wrong starter in? Or do I need a high torque starter or??
mepstein You shouldn't need a hi torque starter on a si... Jan 25 2020, 07:33 AM
Mark Henry I don't know what is causing the delay.
I put... Jan 25 2020, 07:39 AM
I pu... Jan 25 2020, 09:37 AM
jrblackbox
I p... Jan 25 2020, 11:37 AM
Tdskip Odd - maybe a lot of resistance in the wires? Jan 25 2020, 08:03 AM
Superhawk996
Y... Jan 25 2020, 10:31 AM
jrblackbox
... Jan 25 2020, 11:39 AM
Superhawk996
Not 5 seconds, more like a second or 2 only. Def... Jan 25 2020, 01:02 PM
Tom The easiest way to determine if it is the starter ... Jan 25 2020, 12:58 PM
porschetub Sounds like its just dirty inside,they can be slug... Jan 25 2020, 01:14 PM
jrblackbox Thanks all for the info. I will buy a new starter ... Jan 25 2020, 02:07 PM
Mark Henry
Thanks all for the info. I will buy a new starter... Jan 25 2020, 02:20 PM
Superhawk996
Cheaper to do the screwdriver test and if this wo... Jan 25 2020, 02:30 PM
Spoke Sluggish turn-on could be a gummed up bendix. The ... Jan 25 2020, 04:10 PM
jrblackbox Thanks to all that responded to my issue. It was t... Feb 6 2020, 06:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 10:17 AM |
