| adolimpio |
Jan 24 2020, 11:21 PM
Art ![]() ![]() Group: Members Posts: 190 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States
I've read a few threads about the plugs, but there were some competing opinions, so I would like to ask for the latest thoughts.
1. What sealant should be used? One thing was clear - NO TEFLON. The most compelling suggestion was JB Weld. Is that a reasonable solution? 2. What kind of plug? Many opinions say NO to brass or aluminum because their head could be easily stripped. Steel was suggested. How about stainless? Any issue with the different expansion rates between the case and the plugs? One thing is clear - they should be replaced. Of the 11 plugs, 2 almost fell out. They were definitely potential sources of future leaks! Thanks for your thoughts! |
| Mark Henry |
Jan 25 2020, 07:18 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Steel plugs work fine, when you tap make sure it deep enough that the plug sits flush or almost flush, very important with one flywheel side plug. Liquid teflon is OK just not the tape. I don't like JB weld for this as you may need to clean them out next rebuild.
Only the 5 plugs, 3 behind the flywheel and the two at the front need to be done. |
adolimpio Oil Galley Plugs Jan 24 2020, 11:21 PM
cary https://lnengineering.com/type-4-store/type...-ful... Jan 24 2020, 11:54 PM
malcolm2 LN engineering also has a non full flow set. 5 ste... Jan 25 2020, 07:18 AM
Superhawk996 I'll stir the pot. :stir:
Aluminum plugs a... Jan 25 2020, 09:36 AM
Mark Henry In this case it doesn't really matter which ma... Jan 25 2020, 01:58 PM
Superhawk996
The dissimilar metals/leakage theory is just a no... Jan 25 2020, 02:53 PM
dr914@autoatlanta.com empi makes a nice assortment set Jan 25 2020, 03:16 PM
malcolm2
Come on Doc, y... Jan 25 2020, 07:37 PM
adolimpio Thanks for all the help, it was very useful. Jan 28 2020, 06:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th September 2026 - 06:54 AM |
