| jrblackbox |
Jan 25 2020, 07:01 AM
Member ![]() ![]() Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None
Ok, so I changed out the starter in my 6 with another starter I had collecting dust. Now upon turning the key there is a "delay" of a second or 2 before the car turns over. So when I turn the key I can hear the fuel pump come on, then the delay, then the car will crank. did i put the wrong starter in? Or do I need a high torque starter or??
| porschetub |
Jan 25 2020, 01:14 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,175 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sounds like its just dirty inside,they can be sluggish to turn if the commutator is glazed up with carbon from the brushes or the brushes are worn.
Used to polish the commutators in a lathe after recutting the segments with a modified fine hacksaw blade,brushes don't normally wear too much but aren't hard to change if needs be. Worth checking the solenoid is sticking up also,that can slow things down. Good luck. |
jrblackbox Starter issue Jan 25 2020, 07:01 AM
mepstein You shouldn't need a hi torque starter on a si... Jan 25 2020, 07:33 AM
Mark Henry I don't know what is causing the delay.
I put... Jan 25 2020, 07:39 AM
I pu... Jan 25 2020, 09:37 AM
jrblackbox
I p... Jan 25 2020, 11:37 AM
Tdskip Odd - maybe a lot of resistance in the wires? Jan 25 2020, 08:03 AM
Superhawk996
Y... Jan 25 2020, 10:31 AM
jrblackbox
... Jan 25 2020, 11:39 AM
Superhawk996
Not 5 seconds, more like a second or 2 only. Def... Jan 25 2020, 01:02 PM
Tom The easiest way to determine if it is the starter ... Jan 25 2020, 12:58 PM
jrblackbox Thanks all for the info. I will buy a new starter ... Jan 25 2020, 02:07 PM
Mark Henry
Thanks all for the info. I will buy a new starter... Jan 25 2020, 02:20 PM
Superhawk996
Cheaper to do the screwdriver test and if this wo... Jan 25 2020, 02:30 PM
Spoke Sluggish turn-on could be a gummed up bendix. The ... Jan 25 2020, 04:10 PM
jrblackbox Thanks to all that responded to my issue. It was t... Feb 6 2020, 06:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 10:18 AM |
