| CheeRS |
Jan 27 2020, 04:43 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 5-May 19 From: Paris France Member No.: 23,093 Region Association: France |
Hello, I thing my MC start to die, brakes are spongy and when I keep the pressure on the pedal, slowly, this one continu to join the floor.
Would like to keep the pressure sensor warning, should I find a new MC with this sensor ? 17 or 19 no matter. Thanks Fred from Paris |
| Tbrown4x4 |
Jan 27 2020, 05:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
I'm very happy with my 19mm M/Cyl from 914rubber. I just used the single wire switch that came on it. Still works the same way to ground the warning light circuit, just without the dedicated ground wire.
It's not a pressure switch anyway, it's just a plunger switch that is actuated by a little spool that moves if you lose hydraulic pressure in one side of the brake circuit or the other. |
CheeRS looking for a new master cylinder Jan 27 2020, 04:43 PM
Mark Henry Get the MC from 914rubber, install your old switch... Jan 27 2020, 04:50 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 02:14 PM |
