| Mueller |
Feb 10 2020, 10:47 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
On my sids shifter I would like to remove the rear cover to do a slight modification.
1. Is it a straight remove and replace job? 2. Do I have to worry about gasket thickness like other gaskets in the transmission? 3. It is magnesium correct? |
| mepstein |
Feb 10 2020, 10:59 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,534 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
On my sids shifter I would like to remove the rear cover to do a slight modification. 1. Is it a straight remove and replace job? yes. you do have to keep the gear that sits inside the rear cover in place when you lift off the cover. If it falls on the floor, just make sure to put it back before you close up the case. 2. Do I have to worry about gasket thickness like other gaskets in the transmission? no 3. It is magnesium correct? yes |
Mueller Nose cone question, easy to R&R? Feb 10 2020, 10:47 AM
Mueller thanks! Feb 10 2020, 11:42 AM
Tdskip One tip, that I have not tired, is a bit of grease... Feb 10 2020, 01:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 04:42 PM |
