> D-jet problems
PCH
post Feb 10 2020, 12:43 PM
Does anyone make D-jet wiring harnesses?
I am also wondering if my ECU is giving me problems. I just can't develop any power above about 3,500 rpm under load (such as going up a hill).
I have replaced the throttle body (which improving things for a day), rebuilt the MPS (minor improvement). Valves checked, points and timing checked. Fuel filter replaced. Fuel pressure checked. Throttle body rechecked and readjusted. The engine is a 1911 in a 1971 1.7l and ran fine after the rebuilt (had to be careful not to overrev it in the break in period). Now I can't get it to go above 4,000 rpm underload.
It seems like the last 2 suspects would be the wiring harness and ECU. Does anyone have a working ECU that I could "borrow" to see if my ECU is bad. Or does someone have a tester that could be rented to test the unit.
Any suggestions? Thank you.
913B
post Feb 12 2020, 01:03 AM
Jeff Bowlsby and Mikey914 both make harnesses.
You said you checked the fuel PSI, what kind of pressures were you getting.
Has the fuel tank ever been cleaned or the original? The reason is my friend's car had same thing and the filter screen at the bottom of the tank was clogged from rust and sediments.
- Lo-Fi Version Time is now: 2nd April 2026 - 02:33 PM
