> EE question...D-Jet related
Mueller
post Dec 9 2004, 03:07 PM
914 Freak!
What I want to do is have 1 12vdc square wave input, with a "splitter" that will alternate between 2 outputs, I want to do this electronically, and not with a Hall type sensor going high or low to reset
Mueller
post Dec 9 2004, 05:11 PM
914 Freak!
yes to a bunch of the questions (IMG:style_emoticons/default/smile.gif)
trying to eliminate the trigger points in the base of the distributor for the D-Jet
with the L-Jet, all 4 injectors fire when the coil collapses, with the D-Jet, there is a cam lobe on the dizzy shaft that in normally open, right before the intake opens, the contacts touch, sending a small 12vdc signal to the ECU, the ECU then grounds the injectors firing one pair (every ignition cycle one or the other contact closes completing the loop)....very small amperage amount from what I have read, less than the contact points driving the coil.
not sure if the ECU cares about dwell or not, it could be as simple as on/off, same as the L-Jet, as long as there is a voltage differantial, the trigger works
Mueller   EE question...D-Jet related   Dec 9 2004, 03:07 PM
Root_Werks   I thought I knew the D-jet system pretty well, wha...   Dec 9 2004, 03:53 PM
lapuwali   You trying to simulate trigger points? Sounds lik...   Dec 9 2004, 04:02 PM
bondo   http://www.fairchildsemi.com/pf/MM/MM74C374.html ...   Dec 9 2004, 04:37 PM
davep   This thread is useless without more data. A squar...   Dec 9 2004, 04:48 PM
bondo   I *THINK* he is trying to modify a basic tach sign...   Dec 9 2004, 04:59 PM
Mueller   yes to a bunch of the questions :) trying to elim...   Dec 9 2004, 05:11 PM
McMark   I think there is a small amount of time when both ...   Dec 9 2004, 06:19 PM
lapuwali     Dec 9 2004, 08:05 PM
pbanders   <...   Dec 9 2004, 08:17 PM
lapuwali
  Dec 9 2004, 09:05 PM
davep   The trigger points create a fairly short pulse. Sh...   Dec 9 2004, 10:02 PM
bondo   Now that I think about it, the two trigger points ...   Dec 9 2004, 10:49 PM
bondo   I know you wanted to avoid a hall type sensor, but...   Dec 9 2004, 10:53 PM
vsg914     Dec 9 2004, 10:55 PM
Jeff Bowlsby   The trigger points only tell the alternating pairs...   Dec 9 2004, 10:56 PM
bondo     Dec 9 2004, 11:00 PM
vsg914   Royce, I try not to think why. It just confuses me...   Dec 9 2004, 11:05 PM
Mueller   James is correct...Mallory Unilite distributor, ha...   Dec 9 2004, 11:36 PM
scott thacher   why not just put a pick up on the fly wheel to tri...   Dec 9 2004, 11:59 PM
McMark   After thinking about this for awhile, I'll hav...   Dec 10 2004, 01:35 AM
DNHunt   Mike It looks to me like you need to find the rig...   Dec 10 2004, 07:57 AM
scott thacher     Dec 10 2004, 08:47 AM
mikerose   Hi Mike, This is were I say :finger2: :finger2: ...   Dec 10 2004, 10:05 AM
McMark
- Lo-Fi Version Time is now: 16th July 2025 - 03:41 PM
