LS-1 conversion advice needed, Problem solved ! See pg.2 |
drifter914 |
Feb 17 2020, 10:16 AM
drifter914 Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
I have a '76 914 with a 2000 LS-1 engine & Renegade kit I have been sorting out over the past 2 years. It's now a dependable, roadworthy car w/ '84 Carrera front suspension. rear Rebel Racing Bilstein coilovers w/ 200# springs, etc, a dedicated aluminum V-8 conversion, pretty well sorted & a joy to drive !
However, the car came to me with no T-stat in the cooling system & this engine needs a thermostat to run properly. Where & how do I install one ? I have a 3-port electric water pump mounted near the alternator on lower left side of engine. It has a large (1.25") hose on center port and 2 smaller hoses top & bottom, all located in front, center plate of pump. The plumbing details of this cooling system are somewhat complicated, but I'm assuming they are properly arranged, as the car always runs cool. I have an aluminum T-stat housing made to be installed in line in a 1.25" dia. hose. Both lines running to & from the radiator are 1.25", as is the center port hose on the water pump. Not sure if I can use the housing, but I have it if needed. So, where should I locate the thermostat & how ? Ideally the button side of it would be next to the hot water from engine so it can open at the prescribed temp. Hoping for a solution here.. I realize this is an air cooled forum, but have been a member here long enough to know there are many of you running SBC conversions & hoping someone will have the correct answer. Thanks for helping... Terry |
drifter914 |
Feb 17 2020, 02:38 PM
Hello there 914-4me & valco Oscar ! Thanks for chiming in...
I will contact Renegade re: thermo placement. Oscar & I have very similar projects at the moment. He is just getting back to work on his LS project, where mine is complete & a driver. Seems we have a lot to discuss. Still no answer to my question though... where & how to put the thermostat for a LS-1 conversion. best to all teeners... Terry |
Lo-Fi Version | Time is now: 12th June 2024 - 05:41 AM |
