| drifter914 |
Feb 17 2020, 10:16 AM
drifter914 ![]() ![]() Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region |
I have a '76 914 with a 2000 LS-1 engine & Renegade kit I have been sorting out over the past 2 years. It's now a dependable, roadworthy car w/ '84 Carrera front suspension. rear Rebel Racing Bilstein coilovers w/ 200# springs, etc, a dedicated aluminum V-8 conversion, pretty well sorted & a joy to drive !
However, the car came to me with no T-stat in the cooling system & this engine needs a thermostat to run properly. Where & how do I install one ? I have a 3-port electric water pump mounted near the alternator on lower left side of engine. It has a large (1.25") hose on center port and 2 smaller hoses top & bottom, all located in front, center plate of pump. The plumbing details of this cooling system are somewhat complicated, but I'm assuming they are properly arranged, as the car always runs cool. I have an aluminum T-stat housing made to be installed in line in a 1.25" dia. hose. Both lines running to & from the radiator are 1.25", as is the center port hose on the water pump. Not sure if I can use the housing, but I have it if needed. So, where should I locate the thermostat & how ? Ideally the button side of it would be next to the hot water from engine so it can open at the prescribed temp. Hoping for a solution here.. I realize this is an air cooled forum, but have been a member here long enough to know there are many of you running SBC conversions & hoping someone will have the correct answer. Thanks for helping... Terry |
| dwillouby |
Feb 18 2020, 10:42 AM
Member ![]() ![]() Group: Members Posts: 395 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None
Hello
This is how Renegade said to plumb my LS2. I have the inline thermostat up near the radiator on the hot side. David ![]() |
| Daryl32 |
Feb 18 2020, 08:02 PM
Member ![]() ![]() Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California |
Hello This is how Renegade said to plumb my LS2. I have the inline thermostat up near the radiator on the hot side. David ![]() This looks correct - basically the same as with a older v8 - stopping/controlling the water going into the radiator from the engine. So that it can warm up to correct operating temp. |
drifter914 LS-1 conversion advice needed Feb 17 2020, 10:16 AM
9144me2enjoy You might want to contact Renegade Hybrids, theyâ€... Feb 17 2020, 10:46 AM
ValcoOscar Hey Terry-
:wttc: ...it's been awhile
I sen... Feb 17 2020, 11:54 AM
drifter914 Hello there 914-4me & valco Oscar ! Thank... Feb 17 2020, 02:38 PM
drifter914
Hello there 914-4me & valco Oscar ! Than... Mar 8 2020, 11:47 AM
BIGKAT_83 Needs to go on the high pressure hose going to the... Feb 17 2020, 03:09 PM
Daryl32
Needs to go on the high pressure hose going to th... Feb 17 2020, 07:59 PM
drifter914
Needs to go on the high pressure hose going to th... Feb 18 2020, 09:06 AM
Daryl32
Needs to go on the high pressure hose going to t... Feb 18 2020, 09:24 AM
drifter914
[quote name='drifter914' post='2786941' date='Feb... Feb 18 2020, 09:58 AM
Daryl32 Any pictures of the front of the engine and water ... Feb 17 2020, 07:55 PM
DickSteinkamp I think Daryl has a traditional small block.
It l... Feb 18 2020, 10:17 AM
Daryl32
Hello
This is how Renegade said to plumb my LS2... Feb 18 2020, 08:08 PM
Daryl32 Ok Terry - Dick is correct. I did not know how a L... Feb 18 2020, 07:58 PM
Daryl32 Terry and David
Have you seen this video?
Seems... Feb 18 2020, 09:17 PM
drifter914 Wow ! By inquiring from the Forum, I have rea... Feb 19 2020, 04:22 PM
DickSteinkamp Beautiful car. Love the white. Feb 19 2020, 07:58 PM
drifter914
Gran Prix white... Feb 21 2020, 09:35 AM
Daryl32 You should get a lot of good days for driving your... Feb 22 2020, 08:56 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:11 PM |
