> LS-1 conversion advice needed, Problem solved ! See pg.2
drifter914
post Feb 17 2020, 10:16 AM
drifter914
I have a '76 914 with a 2000 LS-1 engine & Renegade kit I have been sorting out over the past 2 years. It's now a dependable, roadworthy car w/ '84 Carrera front suspension. rear Rebel Racing Bilstein coilovers w/ 200# springs, etc, a dedicated aluminum V-8 conversion, pretty well sorted & a joy to drive !
However, the car came to me with no T-stat in the cooling system & this engine needs a thermostat to run properly.
Where & how do I install one ? I have a 3-port electric water pump mounted near the alternator on lower left side of engine. It has a large (1.25") hose on center port and 2 smaller hoses top & bottom, all located in front, center plate of pump.
The plumbing details of this cooling system are somewhat complicated, but I'm assuming they are properly arranged, as the car always runs cool.
I have an aluminum T-stat housing made to be installed in line in a 1.25" dia. hose.
Both lines running to & from the radiator are 1.25", as is the center port hose on the water pump. Not sure if I can use the housing, but I have it if needed.
So, where should I locate the thermostat & how ?
Ideally the button side of it would be next to the hot water from engine so it can open at the prescribed temp.
Hoping for a solution here.. I realize this is an air cooled forum, but have been a member here long enough to know there are many of you running SBC conversions & hoping someone will have the correct answer.
Thanks for helping... Terry
DickSteinkamp
post Feb 19 2020, 07:58 PM
Beautiful car. Love the white.
drifter914
post Feb 21 2020, 09:35 AM
drifter914
QUOTE(DickSteinkamp @ Feb 19 2020, 06:58 PM) *
Gran Prix white, a 911 color. Steel flairs, body prep & paint done by Eugene Rice of Gene's Auto Haven
Sandy, Utah.
Hoping someone with a correct LS install in a 914 will respond with a solution to t-stat placement.
Meanwhile... a few more pics...
Attached Image Attached ImageAttached ImageAttached Image[attachmentid=731
235]
drifter914   LS-1 conversion advice needed   Feb 17 2020, 10:16 AM
9144me2enjoy   You might want to contact Renegade Hybrids, theyâ€...   Feb 17 2020, 10:46 AM
ValcoOscar   Hey Terry- :wttc: ...it's been awhile I sen...   Feb 17 2020, 11:54 AM
drifter914   Hello there 914-4me & valco Oscar ! Thank...   Feb 17 2020, 02:38 PM
drifter914   Hello there 914-4me & valco Oscar ! Than...   Mar 8 2020, 11:47 AM
BIGKAT_83   Needs to go on the high pressure hose going to the...   Feb 17 2020, 03:09 PM
Daryl32   Needs to go on the high pressure hose going to th...   Feb 17 2020, 07:59 PM
drifter914   Needs to go on the high pressure hose going to th...   Feb 18 2020, 09:06 AM
Daryl32   Needs to go on the high pressure hose going to t...   Feb 18 2020, 09:24 AM
drifter914   [quote name='drifter914' post='2786941' date='Feb...   Feb 18 2020, 09:58 AM
Daryl32   Any pictures of the front of the engine and water ...   Feb 17 2020, 07:55 PM
DickSteinkamp   I think Daryl has a traditional small block. It l...   Feb 18 2020, 10:17 AM
dwillouby   Hello This is how Renegade said to plumb my LS2....   Feb 18 2020, 10:42 AM
Daryl32   Hello This is how Renegade said to plumb my LS2...   Feb 18 2020, 08:02 PM
Daryl32   Hello This is how Renegade said to plumb my LS2...   Feb 18 2020, 08:08 PM
Daryl32   Ok Terry - Dick is correct. I did not know how a L...   Feb 18 2020, 07:58 PM
Daryl32   Terry and David Have you seen this video? Seems...   Feb 18 2020, 09:17 PM
drifter914   Wow ! By inquiring from the Forum, I have rea...   Feb 19 2020, 04:22 PM
DickSteinkamp   Beautiful car. Love the white.   Feb 19 2020, 07:58 PM
drifter914   Beautiful car. Love the white. Gran Prix white...   Feb 21 2020, 09:35 AM
Daryl32   You should get a lot of good days for driving your...   Feb 22 2020, 08:56 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:40 PM
