| Mr. M |
Feb 22 2020, 08:06 AM
Newbie ![]() Group: Members Posts: 16 Joined: 16-May 17 From: Midwest Member No.: 21,111 Region Association: Upper MidWest |
I did a search, but I didn't come up with the information that I was looking for, has anyone put together their own bump steer kit? Hoping to find out where people were able to source the parts from or a parts list that they used to make the kit.
| 914forme |
Feb 22 2020, 11:08 AM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
You can do it, by chance you own a metal lathe?
Lots of details in that kit, and I do not like them as a single sheer point. Properly done with another arm welded at the bottom of the strut, to make it a double sheer situation. Oh the leverage going on with that setup. Making the proper bump-steer kit like shown by Mark is easier. I never did it, but thought about it long and hard, is to measure it, setup tests with washers, get the right height with Zero bump steer, and then machine a spacers the proper height. One item of note, I have removed the center rubber steering spacer to get the geometry back in proper place. My last setup, I did that and removed the shaft under the dash, and sectioned it, then welded the tube, ground it down, and added a sleeve. That allowed the U-joints nit to bind under the dash. With out this I got an effort sine Waze going as I turned the car. Last version I was going with the kit much like you see there, but in double sheer. I left the rubber isolator out of the steering. |
Mr. M DIY Bump Steer Kit Feb 22 2020, 08:06 AM
914Sixer Bump steer kits usually consists of two thick spac... Feb 22 2020, 10:21 AM
Bump steer kits usually consists of two thick spa... Feb 22 2020, 12:31 PM
stownsen914 I'll offer a counter point to the concerns abo... Feb 22 2020, 12:41 PM
I'll offer a counter point to the concerns ab... Feb 22 2020, 12:57 PM
Tdskip
Bump steer kits usually consists of two thick sp... Feb 23 2020, 08:36 AM
mepstein The $300-400 kits are for when you raise the ... Feb 22 2020, 10:25 AM
worn
... Feb 22 2020, 06:38 PM
914forme
... Feb 22 2020, 09:21 PM
Mark Henry The bigest hurtle is a metric thread ball joint an... Feb 22 2020, 11:38 AM
roblav1 I believe those spacers raise the steering rack.
T... Feb 22 2020, 05:36 PM
914forme Not sure unless you do not fix all the issues it c... Feb 23 2020, 11:20 AM
Mark Henry There's a huge thread on bump steer in the cla... Feb 23 2020, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:20 AM |
