3.2 conversion wiring question, does the pms wiring harness has a red wire for pressure sendor? |
buck toenges |
Feb 22 2020, 11:44 AM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I am having problems tracing the red wire from the oil pressure sender of a 1988 3.2 engine through my 914 so I can hook up my oil pressure gauge. So far I haven't found the wire through the 914 body harness by using a continuity check. I have a pms wiring conversion harness and by looking at the diagram it looks like the oil pressure wire is a red wire on pin location 4 on the 911 side. Can anybody help me locate the proper wire for the oil pressure gauge? Is it indeed red and does this wire run from the pms harness through to the dme harness and change color?
Thanks, Buck |
Maltese Falcon |
Feb 22 2020, 12:14 PM
Advanced Member Group: Members Posts: 4,695 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
On my six conversion (1974 car) I've run the o/p gauge wire on its own ; usually not found on the plug-in harness.
Lo-Fi Version | Time is now: 8th June 2024 - 05:15 PM |
