| Mr. M |
Feb 22 2020, 08:06 AM
Newbie ![]() Group: Members Posts: 16 Joined: 16-May 17 From: Midwest Member No.: 21,111 Region Association: Upper MidWest |
I did a search, but I didn't come up with the information that I was looking for, has anyone put together their own bump steer kit? Hoping to find out where people were able to source the parts from or a parts list that they used to make the kit.
| 914Sixer |
Feb 22 2020, 10:21 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Bump steer kits usually consists of two thick spacers that go under the steering rack and longer bolts.
| SirAndy |
Feb 22 2020, 12:31 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Bump steer kits usually consists of two thick spacers that go under the steering rack and longer bolts. Please don't use those. It's the worst way possible to go about correcting the steering geometry. (IMG:style_emoticons/default/icon8.gif) (IMG:style_emoticons/default/barf.gif) |
| stownsen914 |
Feb 22 2020, 12:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 996 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I'll offer a counter point to the concerns about using spacers and a (semi) long bolt to attach a tie rod to the strut. There isn't THAT much force on a tie rod end, compared to other suspension joints. For a tie rod I'd rather have a single shear bolt as a weak link if a wheel takes a significant hit, and have the bolt bend, rather than having a double shear setup and transmit the entire force to the steering rack.
I've had a single shear setup on my racecar for many years and haven't had a problem yet. I do have a large washer on the outboard end of the rod end joint so it won't pop up in case of damage. |
Mr. M DIY Bump Steer Kit Feb 22 2020, 08:06 AM
I'll offer a counter point to the concerns ab... Feb 22 2020, 12:57 PM
Tdskip
Bump steer kits usually consists of two thick sp... Feb 23 2020, 08:36 AM
mepstein The $300-400 kits are for when you raise the ... Feb 22 2020, 10:25 AM
914forme You can do it, by chance you own a metal lathe?
L... Feb 22 2020, 11:08 AM
worn
... Feb 22 2020, 06:38 PM
914forme
... Feb 22 2020, 09:21 PM
Mark Henry The bigest hurtle is a metric thread ball joint an... Feb 22 2020, 11:38 AM
roblav1 I believe those spacers raise the steering rack.
T... Feb 22 2020, 05:36 PM
914forme Not sure unless you do not fix all the issues it c... Feb 23 2020, 11:20 AM
Mark Henry There's a huge thread on bump steer in the cla... Feb 23 2020, 11:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:21 AM |
