| DRPHIL914 |
Jan 16 2020, 04:57 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
A few issues here , after the bushing disintegrated I ordered new stuff, a new firewall bushing from RIX914PARTS and other goodies from 914rubber.com, and a new brass bushing for the coupling, however I can’t get the pin out, and I’m going to mess up the pin end and it’s not going to slide thru if I do that- so I’m going to have to find a press I guess somewhere?
1. Should it be that tight ? 2. Is this a normal weld end? Attached thumbnail(s) |
| Olympic 914 |
Feb 21 2020, 06:58 PM
![]() ![]() ![]() Group: Members Posts: 1,771 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
That s the first time I have seen the bronze coupler bushings. Who sells them?
I already have the bronze shifter console bushing. and it was a little stiff until it wore in some. |
| maf914 |
Feb 23 2020, 07:41 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
That s the first time I have seen the bronze coupler bushings. Who sells them? I already have the bronze shifter console bushing. and it was a little stiff until it wore in some. Pelican Parts has them listed. https://www.pelicanparts.com/catalog/SuperC...T_pg2.htm#item5 |
DRPHIL914 Shift rod - Update- new brass bushings, and another option-a 911 coupler from Rauch & Spiegel Jan 16 2020, 04:57 PM
dr914@autoatlanta.com lube the pin, support the coupler in a vice with w... Jan 16 2020, 05:25 PM
BeatNavy That was one of the more frustrating tasks I'v... Jan 16 2020, 06:05 PM
mepstein You will never regret getting a press. It’s one ... Jan 16 2020, 06:14 PM
BeatNavy
You will never regret getting a press. It’s one... Jan 16 2020, 06:34 PM
jmitro
You will never regret getting a press. It’s one... Jan 16 2020, 10:27 PM
Chris914n6 2. Normal
The coupler is not that strong. It... Jan 16 2020, 06:36 PM
poorsche914
2. Normal
The coupler is not that strong. It... Jan 16 2020, 09:12 PM
DRPHIL914
2. Normal
The coupler is not that strong. It... Jan 16 2020, 09:19 PM
IronHillRestorations I've done a bunch of those. I use two sockets... Jan 16 2020, 11:04 PM
anderssj Dr. Phil,
A couple of links I found helpful:
htt... Jan 17 2020, 08:53 AM
rhodyguy From the pictures the pin ends look pretty distort... Jan 18 2020, 11:32 AM
From the pictures the pin ends look pretty distor... Jan 18 2020, 12:14 PM
DRPHIL914
From the pictures the pin ends look pretty disto... Jan 18 2020, 03:21 PM
DRPHIL914 https://sierramadrecollection.com/Shift-Cou...-88-... Jan 18 2020, 03:26 PM
Mikey914 Why replace a perfectly good part ?
You still have... Jan 18 2020, 04:19 PM
Mark Henry Six inch vice, the two socket method....and that w... Jan 18 2020, 07:29 PM
rhodyguy 1/2 step forward and 4 steps backwards with those ... Jan 18 2020, 08:59 PM
mlindner DrPhil, if all fails, I do have a nice one for sal... Jan 19 2020, 06:26 AM
DRPHIL914
DrPhil, if all fails, I do have a nice one for sa... Jan 19 2020, 06:01 PM
Tdskip Personally I’d replace it since if the repairs a... Jan 19 2020, 07:57 AM
TheCabinetmaker 911 has an oval hole in the bushings that won... Jan 19 2020, 08:43 AM
DRPHIL914 Ok tried getting the pin to move with clamp press ... Jan 20 2020, 08:01 PM
Ok tried getting the pin to move with clamp press... Jan 20 2020, 08:06 PM
DRPHIL914 Posting an update! I had given up after taking... Jan 30 2020, 11:52 AM
SirAndy :first: Jan 30 2020, 12:15 PM
DRPHIL914 i wish I had taken better pictures of the pin to s... Jan 30 2020, 12:41 PM
914Sixer Here is mine using the later stouter 911 coupler. ... Jan 30 2020, 02:11 PM
DRPHIL914
Here is mine using the later stouter 911 coupler.... Jan 30 2020, 05:27 PM
DRPHIL914 Update:
Just got a couple pictures of that shift ... Feb 21 2020, 08:51 AM
DRPHIL914
That s the first time I have seen the bronze coup... Feb 21 2020, 07:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:02 PM |
