Is It Locked |
Is It Locked |
SuperSquid |
Feb 26 2020, 07:27 PM
Newbie Group: Members Posts: 24 Joined: 26-February 20 From: Louisville Kentucky Member No.: 23,972 Region Association: South East States |
Hello All From Kentucky!
I just purchased 1974 914 in Ohio. Overall it looks to be in good condition. I tried to start the old girl and all I get is a loud "CLICK" from the starter. I pulled the plugs and filled the cylinders with Marvin's Mystery Oil. Still just a click. My Question: Is there an easy way to hand-crank the engine so I can check that it NOT seized? Can I just put it in gear and push it to spin the engine? Any and all advice is welcome. Fingers crossed the engine is NOT sized. |
michael7810 |
Feb 26 2020, 08:27 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
You can try the alternator hub nut which should turn the motor if it’s not seized. I wouldn’t recommend breaking it loose because something will break. If you can’t turn it with the alternator I would keep trying penetrating oil in the cylinders. This assumes you checked the condition of the battery, cables and starter first.
Lo-Fi Version | Time is now: 11th June 2024 - 11:52 AM |
