1.7L to 2056 |
1.7L to 2056 |
sreyemj |
Feb 26 2020, 03:47 PM
Member Group: Members Posts: 87 Joined: 12-January 20 From: SA, TX Member No.: 23,821 Region Association: None |
I have a 1.7L motor in my project 914 that needs to be refreshed and I'm thinking of converting it to a 2056 at the same time. This is a somewhat budget build, I'm on a timeline to get it back on the road this summer and as a student there's no way I can justify buying a 9k kit. After looking through quite a few threads on the subject, I'm considering having the case line bored and checked by Tims ACVW in Kent, WA (or maybe there is someone else in Washington State I should consider?). I would prefer to assemble the engine myself if I have time (depending on the rest of the car), otherwise I'll have it assembled.
FAT/Rimco have a 2056 short block kit including pistons and cylinders for $1800 and 1.7L head exchange with 42x36mm valves for $1600. I'm not sure than includes opening the heads up for 96mm cylinders. The FC 442 camshaft looks to be more for carbs, I'm thinking I may want a different camshaft so I can stay with my stock D-jet. Anyone have any experience or input on the FAT/Rimco kit or heads? Is there another option I should consider at the price point? Short block kit: https://fatperformance-rimco.com/products/t...short-block-kit Heads: https://fatperformance-rimco.com/collection...-heads-exchange |
barefoot |
Feb 26 2020, 08:53 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I had my 2L case line bored by John Slack in Olympia Wa. He purchased the new main bearings and did the new bores specifically around the size of these bearings. He also fly cut the cylinder base spigots, and had my crank re-ground to first undersize and did the conversion for tapped oil gallery plugs.
He rebuilds Rolls Royce aircraft engines and I was very impressed with his tooling. He goes by "Jesco Reient" here |
Lo-Fi Version | Time is now: 1st June 2024 - 03:11 PM |
