1.7L to 2056 |
1.7L to 2056 |
sreyemj |
Feb 26 2020, 03:47 PM
Member Group: Members Posts: 87 Joined: 12-January 20 From: SA, TX Member No.: 23,821 Region Association: None |
I have a 1.7L motor in my project 914 that needs to be refreshed and I'm thinking of converting it to a 2056 at the same time. This is a somewhat budget build, I'm on a timeline to get it back on the road this summer and as a student there's no way I can justify buying a 9k kit. After looking through quite a few threads on the subject, I'm considering having the case line bored and checked by Tims ACVW in Kent, WA (or maybe there is someone else in Washington State I should consider?). I would prefer to assemble the engine myself if I have time (depending on the rest of the car), otherwise I'll have it assembled.
FAT/Rimco have a 2056 short block kit including pistons and cylinders for $1800 and 1.7L head exchange with 42x36mm valves for $1600. I'm not sure than includes opening the heads up for 96mm cylinders. The FC 442 camshaft looks to be more for carbs, I'm thinking I may want a different camshaft so I can stay with my stock D-jet. Anyone have any experience or input on the FAT/Rimco kit or heads? Is there another option I should consider at the price point? Short block kit: https://fatperformance-rimco.com/products/t...short-block-kit Heads: https://fatperformance-rimco.com/collection...-heads-exchange |
rbzymek |
Feb 27 2020, 09:21 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
sreyemj, You may want to consider a 2056 SCAT long block for about $3600. I replaced my worn out 1.8 last year and I am pleased with the result. If you are short on time it will get back on the road sooner. |
Lo-Fi Version | Time is now: 8th June 2024 - 10:36 AM |
