1.7L to 2056 |
1.7L to 2056 |
sreyemj |
Feb 26 2020, 03:47 PM
Member Group: Members Posts: 87 Joined: 12-January 20 From: SA, TX Member No.: 23,821 Region Association: None |
I have a 1.7L motor in my project 914 that needs to be refreshed and I'm thinking of converting it to a 2056 at the same time. This is a somewhat budget build, I'm on a timeline to get it back on the road this summer and as a student there's no way I can justify buying a 9k kit. After looking through quite a few threads on the subject, I'm considering having the case line bored and checked by Tims ACVW in Kent, WA (or maybe there is someone else in Washington State I should consider?). I would prefer to assemble the engine myself if I have time (depending on the rest of the car), otherwise I'll have it assembled.
FAT/Rimco have a 2056 short block kit including pistons and cylinders for $1800 and 1.7L head exchange with 42x36mm valves for $1600. I'm not sure than includes opening the heads up for 96mm cylinders. The FC 442 camshaft looks to be more for carbs, I'm thinking I may want a different camshaft so I can stay with my stock D-jet. Anyone have any experience or input on the FAT/Rimco kit or heads? Is there another option I should consider at the price point? Short block kit: https://fatperformance-rimco.com/products/t...short-block-kit Heads: https://fatperformance-rimco.com/collection...-heads-exchange |
BeatNavy |
Feb 27 2020, 06:13 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
This is really good read. Seems like you already know most of this, but Jake puts it all in one place well organized: http://www.914world.com/bbs2/index.php?s=&...t&p=1529209
I bought a machined (align bored, decked) case from Jesco a couple of years ago (it then went to Michigan and McMark turned it into a 2258. It's on my garage floor waiting to go into my car when spring comes (IMG:style_emoticons/default/smile.gif) ). His machining skills appear to be epic, and he seemed like a really good guy in the few interactions I had with him. He's not that active here, but you can PM him I'm sure. I built a 2056 from a 1.7L last year. I didn't go "exotic," but I also didn't cut any corners. I spent over $5K in parts and services, including (biggest ticket items): 1. Brand new 2.0 AA (ceramic coated) heads built by Len Hoffman: $1700 2. Raby 9950 Cam kit: $950 3. P&C: roughly $500 (my records are screwed up here because I swapped from valve relief JE to flat top KB at the end, and I don't seem to have cost on the KB pistons) 4. 2.0 H beam connection rods: $300 5. 71mm crankshaft $300 6. New pushrod tubes: $100 7. Case machining, flywheel resurfacing, parts balancing, etc. $400 8. Rocker machining and miscellaneous tools, shims, etc.: $250 etc. etc. You can definitely do it way cheaper, and I know you're on a budget, but I am curious as to what is reasonable economical rebuild (obviously depends on what you can reuse). When I did this rebuild my thought process was "don't skimp ANYWHERE." Right now I've got a 2 liter on an engine stand partially torn down. I'm toying with trying to do an economical rebuild on it, just for fun. My thought process on this one would be "I don't want to spend $5K on an engine I don't need." |
Bleyseng |
Feb 27 2020, 12:26 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
This is really good read. Seems like you already know most of this, but Jake puts it all in one place well organized: http://www.914world.com/bbs2/index.php?s=&...t&p=1529209 I bought a machined (align bored, decked) case from Jesco a couple of years ago (it then went to Michigan and McMark turned it into a 2258. It's on my garage floor waiting to go into my car when spring comes (IMG:style_emoticons/default/smile.gif) ). His machining skills appear to be epic, and he seemed like a really good guy in the few interactions I had with him. He's not that active here, but you can PM him I'm sure. I built a 2056 from a 1.7L last year. I didn't go "exotic," but I also didn't cut any corners. I spent over $5K in parts and services, including (biggest ticket items): 1. Brand new 2.0 AA (ceramic coated) heads built by Len Hoffman: $1700 2. Raby 9950 Cam kit: $950 3. P&C: roughly $500 (my records are screwed up here because I swapped from valve relief JE to flat top KB at the end, and I don't seem to have cost on the KB pistons) 4. 2.0 H beam connection rods: $300 5. 71mm crankshaft $300 6. New pushrod tubes: $100 7. Case machining, flywheel resurfacing, parts balancing, etc. $400 8. Rocker machining and miscellaneous tools, shims, etc.: $250 etc. etc. You can definitely do it way cheaper, and I know you're on a budget, but I am curious as to what is reasonable economical rebuild (obviously depends on what you can reuse). When I did this rebuild my thought process was "don't skimp ANYWHERE." Right now I've got a 2 liter on an engine stand partially torn down. I'm toying with trying to do an economical rebuild on it, just for fun. My thought process on this one would be "I don't want to spend $5K on an engine I don't need." This is exactly the way I would recommend going too. Have the case checked first before having it line bored as most 914 1.7l cases don't need it. There are lots of good used 2.0L rods around as buses used them too. Len's heads are top notch and the way to go. (I have them) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:54 PM |
