| JoeDees |
Jun 30 2015, 09:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 515 Joined: 10-November 14 From: Northern Kentucky Member No.: 18,106 Region Association: None |
I've concluded that I need to replace significant portions of the lower wheelhouse, inner long, and the suspension console. I've spent the day researching and reading the classic threads and like many of the rack-like assemblies my predecessors have built. Let's hear some easy but still effective ways to get this thing off the ground and straight enough for structural repairs.
I really like the one for "Bringing out your Dead" but can't quite figure out the points it's mounted. After bracing the doors, can I use the front jack points, a long support along the floors, the outer suspension console, and the trans mount area? I ready for some ideas. I'm trying to develop as many COAs (Courses of Action) as possible. Thanks. |
| sixnotfour |
Mar 1 2020, 06:51 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,288 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
@GaroldShaffer
hijack,,, looks loowww....secrect ?? OH, Its a Subaroo mount (IMG:style_emoticons/default/beerchug.gif) 914forme Attached image(s)
| 914forme |
Mar 1 2020, 07:00 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
(IMG:style_emoticons/default/av-943.gif) Nope just high enough to keep a really low boxer engine in the right place. It was all about keeping heavy really low. That was the shell from my old EG33 build. Engine mounts I had planned to weld a steel plate to the bottom of the engine mount if I thought I need one, I planned on running an AL pan, and had lost one once when my wife drove a Jetta over an man hole cover, on a road they had scarped to resurface. The hit split the pan, but luckily just opened it up enough it would weep. That was one expensive rescue dog. (IMG:style_emoticons/default/dry.gif) Luckily he is a great dog. |
| sixnotfour |
Mar 2 2020, 10:18 AM
(IMG:style_emoticons/default/av-943.gif) Nope just high enough to keep a really low boxer engine in the right place. It was all about keeping heavy really low. That was the shell from my old EG33 build. Engine mounts I had planned to weld a steel plate to the bottom of the engine mount if I thought I need one, I planned on running an AL pan, and had lost one once when my wife drove a Jetta over an man hole cover, on a road they had scarped to resurface. The hit split the pan, but luckily just opened it up enough it would weep. That was one expensive rescue dog. (IMG:style_emoticons/default/dry.gif) Luckily he is a great dog. (IMG:style_emoticons/default/beer.gif) I just read your build thread..subi mount (IMG:style_emoticons/default/popcorn[1].gif) |
DirtyCossack Rotisserie Alternatives Jun 30 2015, 09:05 PM
Mike Bellis I would build a rolling cart. A rotisserie may mak... Jun 30 2015, 09:32 PM
madmax914 Check out Restoration Design's Youtube page, t... Jul 1 2015, 12:14 AM
mbseto Just finished working through that same decision m... Jul 1 2015, 05:50 AM
DirtyCossack I'm looking for a good dolly design. You have ... Jul 1 2015, 11:36 AM
DirtyCossack The wife gave me a go ahead to buy a rotisserie wi... Jul 1 2015, 08:32 PM
mepstein :) Jul 1 2015, 08:40 PM
infraredcalvin The 1.5 feet extra in front and back (if I underst... Jul 1 2015, 11:30 PM
stugray
I had to make a few adjustments based on materia... Jul 2 2015, 08:35 AM
mr914 Either way, door jamb braces are THE NUMBER ONE PR... Jul 2 2015, 12:29 AM
mr914 Bracing photo. Strut and pressure plate used for c... Jul 2 2015, 12:32 AM
Vacca Rabite Build a rotisserie.
You will remove the bumpers an... Jul 2 2015, 05:35 AM
saigon71 If you can find a way to fit a rotisserie in your ... Jul 2 2015, 06:38 AM
mbseto
...but after about $300...
Wow, is that ... Jul 2 2015, 06:51 AM
Amenson If anybody is in the Columbus area I found this on... Jul 2 2015, 06:51 AM
DirtyCossack Thanks for the replies. I'm really leaning tow... Jul 2 2015, 10:21 AM
stugray Buy two engine stands from HF and you have 90% of ... Jul 2 2015, 11:07 AM
Vacca Rabite You need to build it.
Many of us learned to weld b... Jul 2 2015, 11:14 AM
DirtyCossack So the rotisserie is a GO, but it has brought up t... Jul 6 2015, 05:29 PM
cary Next Time ................
https://www.jd2.com/p-9... Jul 7 2015, 06:04 AM
jpnovak Build a 914 version of this. I built one for my 9... Jul 7 2015, 07:14 AM
mbseto I've got two door braces on each side. One go... Jul 7 2015, 07:15 AM
DirtyCossack This is the good kind of worrying that leads to be... Jul 7 2015, 09:31 AM
DirtyCossack Maybe we can make "the bracing, jig, body ali... Jul 7 2015, 10:54 AM
VWTortuga336 I know this is an old post, but :agree:
I'm... Aug 6 2016, 08:40 AM
DirtyCossack
I... Aug 8 2016, 09:11 AM
Mark Henry The young lad needs to build a rotisserie I like t... Aug 6 2016, 09:12 AM
Mark Henry
The young lad needs to build a rotisserie I like ... Aug 6 2016, 09:20 AM
budk
Found the rotisserie they made for the 914 and it... Aug 6 2016, 09:33 AM
Red76 Lots of different designs for rotisseries on here.... Feb 7 2018, 04:08 PM
Red76 A couple more pics Feb 7 2018, 04:16 PM
Dutchy4U anyone who has been restoring chassis complete 914... Apr 25 2019, 05:13 PM
bbrock
anyone who has been restoring chassis complete 91... Apr 26 2019, 07:30 AM
billium01 Not to poopoo RD's rotisserie idea but it look... Apr 25 2019, 08:03 PM
David Billo
Not to poopoo RD's rotisserie idea but it loo... Apr 26 2019, 01:27 PM
Superhawk996 I've accessed all the structural elements you ... Apr 26 2019, 07:05 AM
gereed75 I am about to build a similar chassis dolly but wi... Apr 26 2019, 07:26 AM
Superhawk996
I am about to build a similar chassis dolly but w... Apr 26 2019, 07:33 AM
914werke Depending on YOUR repair (of if you plan on doing ... Apr 26 2019, 11:22 AM
mepstein I would never put a 914 on a rotisserie to fix the... Apr 26 2019, 01:49 PM
mlindner Build a dolly, as high as you want. Mine I even us... Apr 26 2019, 02:08 PM
Stuckon914 Old thread but still valid topic. How far off the ... Feb 28 2020, 05:35 PM
914forme half the width of the widest point on the chassis,... Feb 28 2020, 06:09 PM
Stuckon914
half the width of the widest point on the chassis... Feb 28 2020, 06:52 PM
VaccaRabite Having built one, here is my advice:
1) Don't... Feb 28 2020, 07:01 PM
914forme :agree: And that is why I built mine to be adjusta... Feb 29 2020, 09:22 PM
GaroldShaffer
:agree: And that is why I built mine to be adjust... Feb 29 2020, 10:01 PM
Stuckon914
:agree: And that is why I built mine to be adjus... Mar 1 2020, 06:20 PM
914forme Thank you, and I miss it, but letting it go to a n... Mar 1 2020, 06:52 PM
nathanxnathan I saw this one on Pinterest, and it really inspire... Mar 3 2020, 05:49 PM
PanelBilly My Longs were in good shape, but if I knew better ... Mar 3 2020, 06:20 PM
914forme Interesting, only issue I see is that is all threa... Mar 3 2020, 06:24 PM
nathanxnathan
Interesting, only issue I see is that is all thre... Mar 3 2020, 06:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th July 2026 - 06:30 AM |
