| GregAmy |
Mar 2 2020, 08:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
What should be the maximum capability of the stock D-Jet pressure regulator? Mine only goes to 36.
If that's normal, is there another similar-format regulator that can go up to around 45psi? Background: Microsquirt project. Was hoping to use the stock regulator, but now need something that I can easily mount in the same location, if possible. Injectors I'm using are rated at 43.5psi. Discuss! |
| JeffBowlsby |
Mar 2 2020, 11:45 AM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
As I thought...thats maximum flow, without a safety factor.
GregAmy D-Jet Fuel Pressure Regulator Mar 2 2020, 08:38 AM
914Sixer Stock set to run 28-30. In vapor lock areas up to... Mar 2 2020, 09:31 AM
JeffBowlsby 43.5 PSI is the conversion from 300kPA which is th... Mar 2 2020, 10:06 AM
GregAmy You sure your injectors are rated that high for in... Mar 2 2020, 10:41 AM
nordfisch
- You Posted: Injector Table
Hi Jeff,
the table... Mar 2 2020, 02:33 PM
GregAmy
As I thought...thats maximum flow, without a safe... Mar 2 2020, 11:49 AM
914_teener
As I thought...thats maximum flow, without a saf... Mar 2 2020, 12:58 PM
GregAmy I'm confused. Flow and pressure are related h... Mar 2 2020, 01:19 PM
914_teener
I'm confused. Flow and pressure are related ... Mar 2 2020, 02:29 PM
ChrisFoley
no problem running these at 36psi and putting in... Mar 2 2020, 05:56 PM
GregAmy
Why even go up to 36? Calculate the flow at 30psi... Mar 2 2020, 06:54 PM
JamesM Was poking around a bit and and found these inject... Mar 3 2020, 11:50 PM
Bleyseng The Ljet has a variable fuel pressure regulator to... Mar 2 2020, 12:16 PM
JeffBowlsby Hi Norbert, thank you for the Bosch list its very ... Mar 2 2020, 05:48 PM
nordfisch
... The Weiss chart was a reference for me back t... Mar 3 2020, 02:00 PM
JamesM Higher pressure provides better fuel atomization, ... Mar 3 2020, 03:46 PM
914_teener
Higher pressure provides better fuel atomization,... Mar 3 2020, 05:40 PM
JamesM
I know some folds have done MS systems so maybe t... Mar 3 2020, 07:03 PM
914_teener
I know some folds have done MS systems so maybe ... Mar 3 2020, 08:17 PM
GregAmy The OP didn't say if he was going to retain th... Mar 3 2020, 08:36 PM
914_teener
The OP didn't say if he was going to retain t... Mar 3 2020, 08:41 PM
JamesM
Whole lotta dick-swinging around here and yet...n... Mar 3 2020, 11:09 PM
JeffBowlsby The concern about constant operation at maximum pr... Mar 3 2020, 04:30 PM
JamesM
The concern about constant operation at maximum p... Mar 3 2020, 07:52 PM
JamesM Just remembered I still have the paperwork for min... Mar 4 2020, 12:07 AM
JamesM
What should be the maximum capability of the stoc... Mar 4 2020, 01:39 AM
JamesM Hey, looky what I found....
https://www.injector... Mar 4 2020, 02:15 AM
JamesM Found another picture of the MSD 2222 where you ca... Mar 4 2020, 02:48 AM
GregAmy
Found another picture of the MSD 2222 where you c... Mar 5 2020, 10:08 AM
JamesM
Found another picture of the MSD 2222 where you ... Mar 5 2020, 06:30 PM
GregAmy Still has me curious why you are only seeing ~35.
... Mar 5 2020, 07:27 PM
GregAmy Since we're going deeper into the design...
A... Mar 4 2020, 06:19 AM
JamesM
... Mar 5 2020, 12:29 AM
GregAmy Eric, I'm actually starting to "write all... Mar 5 2020, 06:18 AM
barefoot Many years ago I had a project to design automotiv... Mar 4 2020, 06:19 AM
Montreal914
Though amazon is great and showed me this much c... Mar 5 2020, 12:05 AM
JamesM
[quote name='JamesM' post='2791279' date='Mar 3 2... Mar 5 2020, 09:38 AM
JeffBowlsby Check this.
"35 gal/hr"
Seems a bit ... Mar 5 2020, 08:14 AM
JamesM
Check this.
"35 gal/hr"
Seems a bit... Mar 5 2020, 09:51 AM
JeffBowlsby
Check this.
"35 gal/hr"
Seems a bit... Mar 5 2020, 11:03 AM
GregAmy It's not the pump. I went out there, jumped th... Mar 5 2020, 07:46 PM
ChrisFoley I have a few FPRs here. You're welcome to try ... Mar 6 2020, 06:38 AM
GregAmy Thank you sir!We're already overdue for a ... Mar 6 2020, 07:58 AM
JamesM
Thank you sir!We're already overdue for a... Mar 7 2020, 02:48 AM
Montreal914 Just catching up on the thread this morning.
Greg... Mar 7 2020, 11:03 AM
GregAmy Quick update... per Summit Racing, MSD has discont... Mar 9 2020, 11:40 AM
JamesM Didn't have time to tear into one this weekend... Mar 9 2020, 11:05 PM
JamesM Just did a bit more searching... this is an intere... Mar 10 2020, 12:09 AM
JamesM Knowing that 914 l-jet regulators are a direct swa... Mar 10 2020, 12:27 AM
JamesM This is interesting. In the latest bosch catalog ... Mar 10 2020, 01:22 AM
JamesM https://shopbhp.com/products/kit-car-fuel-p...ant=... Mar 10 2020, 01:49 AM
GregAmy May be more bad news for d-jet
Well crap.
I have ... Mar 10 2020, 06:45 AM
JamesM
Well crap.
I have... Mar 10 2020, 09:07 AM
ChrisFoley Bosch Fuel Pressure Regulator at Pelican Mar 9 2020, 02:26 PM
GregAmy And...they're out of stock. Refers me to ... Mar 9 2020, 04:21 PM
ChrisFoley You might want to start soaking the three used one... Mar 9 2020, 06:14 PM
GregAmy Here's a 3-bar one. eBay ad claims (I think) i... Mar 10 2020, 07:31 AM
GregAmy Am I correct in inferring his non-regulator one is... Mar 10 2020, 09:24 AM
JamesM
Am I correct in inferring his non-regulator one i... Mar 10 2020, 01:13 PM
GregAmy Mario's response, paraphrased:
This:
Univers... Mar 10 2020, 07:14 PM
ChrisFoley That's probably what Mario was thinking you wo... Mar 10 2020, 12:20 PM
GregAmy His stuff looks nice, but I sent an email him to f... Mar 10 2020, 12:59 PM
Montreal914 Seems like the way to go! Mar 10 2020, 09:50 PM
GregAmy Mario 3-bar FPR procured and installed. Shows 41.5... Mar 13 2020, 07:52 PM
ChrisFoley
Asking for a friend. :miles:
:shades2: Mar 14 2020, 05:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:50 PM |
