> D-Jet Fuel Pressure Regulator, How high should it go?
GregAmy
post Mar 2 2020, 08:38 AM
What should be the maximum capability of the stock D-Jet pressure regulator? Mine only goes to 36.
If that's normal, is there another similar-format regulator that can go up to around 45psi?
Background: Microsquirt project. Was hoping to use the stock regulator, but now need something that I can easily mount in the same location, if possible. Injectors I'm using are rated at 43.5psi.
Discuss!
JeffBowlsby
post Mar 2 2020, 11:45 AM
As I thought...thats maximum flow, without a safety factor.
GregAmy
post Mar 2 2020, 11:49 AM
QUOTE(JeffBowlsby @ Mar 2 2020, 12:45 PM) *
So then...where should it be run? Higher pressures reduce duty cycle and vice versa. It'll never run more than 85% duty cycle regardless or I'll swap to higher-flow injectors (which is highly unlikely, given the dead-stock engine's original awesome <90 horsepower and 5800 RPM redline...these should be easily sufficient.)
BTW, I don't see the word "maximum" in there anywhere...all I see is a flow rate at a specified pressure, which as you note you note is standard practice.
Are you recommending not running it at 43.5psi? If not, then where?
914_teener
post Mar 2 2020, 12:58 PM
QUOTE(GregAmy @ Mar 2 2020, 09:49 AM) *
I'm confused. Flow and pressure are related however from Jeff's chart for the low impedance injectors yields 380 cc per minute @ the stock aprox. 2 Bar.
The link you provided for the high impedence injector flows 280 @ aprox 3 bar?
A longer duration would increase the flow rate but isn't this deduced by displacement?
I love to learn.
GregAmy
post Mar 2 2020, 01:19 PM
QUOTE(914_teener @ Mar 2 2020, 01:58 PM) *
With much respect, Jeff's chart is not relevant to this discussion. I am not using 914 D-Jet injectors.
EDIT: Although, is Jeff trying to point out is that D-Jet injectors are all rated at 300kPA but are not actually used at that pressure...?
Correct, thus the point of my query. I'm looking for a factory fuel pressure regulator that will allow me to run 43.5psi. "Factory" because it would be an easy install; "43.5psi" because I want to start with a known 280cc flow rate capabilty in the tuning software (it's one of the required inputs).
I love to learn.
As do I, thus my self-flaggelation instead of staying with a perfectly-functioning D-Jet system (really, it was working fine...even had a newly-rebuilt unable MPS...)
The relationship between pressure and flow is not linear: https://help.summitracing.com/app/answers/d...or-flow-rate%3F
Using that formula, my 280cc (rated) injectors are 26.67 lbs-hr. Using that formula, at 36psi it would be 26.26 lbs/hr or 254.75 (we'll call it 255 for short). That is confirmed by this calculator:
https://deatschwerks.com/fuel-calculators/f...sure-calculator
That said...Jeff is implying that running injectors at their standard rating is not good, that there needs to be a "safety" margin. If I infer that correctly, then there actually may be no problem running these at 36psi and putting in "255" as the flow rate (the Microsquirt has no input of fuel pressure).
I'm just curious if running them at higher pressures is not advantageous in terms of spray pattern and efficiency. Most electronic fuel injector manufacturers are suggesting pressure of 40-80 psi. But for a 100hp (max) crank horsepower 4-cyl engine, 280cc injectors (@43.5psi) are way more than enough...they'll probably be running way low on duty cycle, so maybe lower starting pressure is better...
Regardless, I can tune it to any usable value. And I suspect 36psi is a usable value. Just looking to understand my options.
914_teener
post Mar 2 2020, 02:29 PM
QUOTE(GregAmy @ Mar 2 2020, 11:19 AM) *
I love to learn.
Ah...love the comment on self flagellation.....humility is a rare commodity.
Now when I read rated test pressure at 300 Kpa that is the metric equivalent to test the injector correct?
My understanding of how these things are tested is that under a mean pressure this is to test the injector body where the molded plastic housing for the "pintle" meets the metal injector body IIRC. To see if that point leaks or not.
I am ignorant what the ultimate pressure is for these things but it reads like we are saying that the 300Kpa is testing pressure and not running pressure and the rated flow? Does this make sense?
And yes...I'd share your concern about fuel atomization and efficiency. I know enough about fluid dynamics to be dangerous.
Edit: Forgot to add....300Kpa = 43.5113 psi. So I quess without speaking for Jeff....this is what I think he was talking about...referencing the chart on his website.
Flagellate on please.
GregAmy   D-Jet Fuel Pressure Regulator   Mar 2 2020, 08:38 AM
914Sixer   Stock set to run 28-30. In vapor lock areas up to...   Mar 2 2020, 09:31 AM
JeffBowlsby   43.5 PSI is the conversion from 300kPA which is th...   Mar 2 2020, 10:06 AM
GregAmy   You sure your injectors are rated that high for in...   Mar 2 2020, 10:41 AM
nordfisch   - You Posted: Injector Table Hi Jeff, the table...   Mar 2 2020, 02:33 PM
JeffBowlsby   As I thought...thats maximum flow, without a safet...   Mar 2 2020, 11:45 AM
GregAmy   As I thought...thats maximum flow, without a safe...   Mar 2 2020, 11:49 AM
914_teener   As I thought...thats maximum flow, without a saf...   Mar 2 2020, 12:58 PM
GregAmy   I'm confused. Flow and pressure are related h...   Mar 2 2020, 01:19 PM
914_teener   I'm confused. Flow and pressure are related ...   Mar 2 2020, 02:29 PM
ChrisFoley   no problem running these at 36psi and putting in...   Mar 2 2020, 05:56 PM
GregAmy   Why even go up to 36? Calculate the flow at 30psi...   Mar 2 2020, 06:54 PM
JamesM   Was poking around a bit and and found these inject...   Mar 3 2020, 11:50 PM
Bleyseng   The Ljet has a variable fuel pressure regulator to...   Mar 2 2020, 12:16 PM
JeffBowlsby   Hi Norbert, thank you for the Bosch list its very ...   Mar 2 2020, 05:48 PM
nordfisch   ... The Weiss chart was a reference for me back t...   Mar 3 2020, 02:00 PM
JamesM   Higher pressure provides better fuel atomization, ...   Mar 3 2020, 03:46 PM
914_teener   Higher pressure provides better fuel atomization,...   Mar 3 2020, 05:40 PM
JamesM   I know some folds have done MS systems so maybe t...   Mar 3 2020, 07:03 PM
914_teener   I know some folds have done MS systems so maybe ...   Mar 3 2020, 08:17 PM
GregAmy   The OP didn't say if he was going to retain th...   Mar 3 2020, 08:36 PM
914_teener   The OP didn't say if he was going to retain t...   Mar 3 2020, 08:41 PM
JamesM   Whole lotta dick-swinging around here and yet...n...   Mar 3 2020, 11:09 PM
JeffBowlsby   The concern about constant operation at maximum pr...   Mar 3 2020, 04:30 PM
JamesM   The concern about constant operation at maximum p...   Mar 3 2020, 07:52 PM
JamesM   Just remembered I still have the paperwork for min...   Mar 4 2020, 12:07 AM
JamesM   What should be the maximum capability of the stoc...   Mar 4 2020, 01:39 AM
JamesM   Hey, looky what I found.... https://www.injector...   Mar 4 2020, 02:15 AM
JamesM   Found another picture of the MSD 2222 where you ca...   Mar 4 2020, 02:48 AM
GregAmy   Found another picture of the MSD 2222 where you c...   Mar 5 2020, 10:08 AM
JamesM   Found another picture of the MSD 2222 where you ...   Mar 5 2020, 06:30 PM
GregAmy   Still has me curious why you are only seeing ~35. ...   Mar 5 2020, 07:27 PM
GregAmy   Since we're going deeper into the design... A...   Mar 4 2020, 06:19 AM
JamesM   Since we're going deeper into the design... ...   Mar 5 2020, 12:29 AM
GregAmy   Eric, I'm actually starting to "write all...   Mar 5 2020, 06:18 AM
barefoot   Many years ago I had a project to design automotiv...   Mar 4 2020, 06:19 AM
Montreal914   Though amazon is great and showed me this much c...   Mar 5 2020, 12:05 AM
JamesM   [quote name='JamesM' post='2791279' date='Mar 3 2...   Mar 5 2020, 09:38 AM
JeffBowlsby   Check this. "35 gal/hr" Seems a bit ...   Mar 5 2020, 08:14 AM
JamesM   Check this. "35 gal/hr" Seems a bit...   Mar 5 2020, 09:51 AM
JeffBowlsby   Check this. "35 gal/hr" Seems a bit...   Mar 5 2020, 11:03 AM
GregAmy   It's not the pump. I went out there, jumped th...   Mar 5 2020, 07:46 PM
ChrisFoley   I have a few FPRs here. You're welcome to try ...   Mar 6 2020, 06:38 AM
GregAmy   Thank you sir!We're already overdue for a ...   Mar 6 2020, 07:58 AM
JamesM   Thank you sir!We're already overdue for a...   Mar 7 2020, 02:48 AM
Montreal914   Just catching up on the thread this morning. Greg...   Mar 7 2020, 11:03 AM
GregAmy   Quick update... per Summit Racing, MSD has discont...   Mar 9 2020, 11:40 AM
JamesM   Didn't have time to tear into one this weekend...   Mar 9 2020, 11:05 PM
JamesM   Just did a bit more searching... this is an intere...   Mar 10 2020, 12:09 AM
JamesM   Knowing that 914 l-jet regulators are a direct swa...   Mar 10 2020, 12:27 AM
JamesM   This is interesting. In the latest bosch catalog ...   Mar 10 2020, 01:22 AM
JamesM   https://shopbhp.com/products/kit-car-fuel-p...ant=...   Mar 10 2020, 01:49 AM
GregAmy   May be more bad news for d-jet Well crap. I have ...   Mar 10 2020, 06:45 AM
JamesM   May be more bad news for d-jet Well crap. I have...   Mar 10 2020, 09:07 AM
ChrisFoley   Bosch Fuel Pressure Regulator at Pelican   Mar 9 2020, 02:26 PM
GregAmy   And...they're out of stock. Refers me to ...   Mar 9 2020, 04:21 PM
ChrisFoley   You might want to start soaking the three used one...   Mar 9 2020, 06:14 PM
GregAmy   Here's a 3-bar one. eBay ad claims (I think) i...   Mar 10 2020, 07:31 AM
GregAmy   Am I correct in inferring his non-regulator one is...   Mar 10 2020, 09:24 AM
JamesM   Am I correct in inferring his non-regulator one i...   Mar 10 2020, 01:13 PM
GregAmy   Mario's response, paraphrased: This: Univers...   Mar 10 2020, 07:14 PM
ChrisFoley   That's probably what Mario was thinking you wo...   Mar 10 2020, 12:20 PM
GregAmy   His stuff looks nice, but I sent an email him to f...   Mar 10 2020, 12:59 PM
Montreal914   Seems like the way to go!   Mar 10 2020, 09:50 PM
GregAmy   Mario 3-bar FPR procured and installed. Shows 41.5...   Mar 13 2020, 07:52 PM
ChrisFoley   Asking for a friend. :miles: :shades2:   Mar 14 2020, 05:49 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:53 PM
