| GregAmy |
Mar 2 2020, 08:38 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,651 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
What should be the maximum capability of the stock D-Jet pressure regulator? Mine only goes to 36.
If that's normal, is there another similar-format regulator that can go up to around 45psi? Background: Microsquirt project. Was hoping to use the stock regulator, but now need something that I can easily mount in the same location, if possible. Injectors I'm using are rated at 43.5psi. Discuss! |
| GregAmy |
Mar 4 2020, 06:19 AM
Since we're going deeper into the design...
And, by the way, before we get too deep into this I wanted to recognize the assistance I've received from EricP, @Montreal914 . He has his own build going on but we've been swapping info back and forth. Thanks, Eric! My design basis an over-riding "prime directive": use as many stock components as reasonably possible, and try to design it such that anyone can install it. I also have a design cost of <$1500 in parts. Unless someone wants to take this design and sell it as a kit for the community (and if you do, please contact me), I plan to do a full write-up of parts build lists, sources, design, and instructions. Toward this, my goal is to use the "stock" fuel pump and pressure regulator, if at all possible. I got the pump I'm using from Chris Foley at Tangerine; it is a 2-port replacement for the factory 3-port. He thinks it's the Bosch 69133. I've yet to find any specs on that pump but I havne't looked hard; I was working under the impression that the limiting factor here was the regulator. Maybe that was a flawed ASSumption. More later; time to go to work to pay for all this. - GA EDIT: Current plan is to tune the engine to 35psi, with "255" as the flow number for the injectors. |
| JamesM |
Mar 5 2020, 12:29 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Since we're going deeper into the design... My design basis an over-riding "prime directive": use as many stock components as reasonably possible, and try to design it such that anyone can install it. I also have a design cost of <$1500 in parts. Unless someone wants to take this design and sell it as a kit for the community (and if you do, please contact me), I plan to do a full write-up of parts build lists, sources, design, and instructions. Toward this, my goal is to use the "stock" fuel pump and pressure regulator, if at all possible. Totally possible but you may be better off just running d-jet, l-jet, or possibly vanagon injectors, with load resistors at the stock pressures in that case. Pretty much every d-jet component except for the throttle position sensor can be re-used in a Megasquirt build (including the stock wiring harness if you are crafty enough) but having run one like that for ~15 years I can tell you it has its short comings. My first d-jet to MS conversion i think my total parts cost including the MS ECU components (I soldered it myself) was roughly around $150 bucks, but the necessary labor was beyond what i would recommend to anyone. I got the pump I'm using from Chris Foley at Tangerine; it is a 2-port replacement for the factory 3-port. He thinks it's the Bosch 69133. I've yet to find any specs on that pump but I havne't looked hard; I was working under the impression that the limiting factor here was the regulator. Maybe that was a flawed ASSumption. More later; time to go to work to pay for all this. - GA Not sure about the Bosch 69133 but the factory 2 ports are also supposed to have a built in over-pressure circuit. Hard to say what might be limiting your total pressure but that MSD FPR that is rated 36-42 PSI has the Bosch d-jet part number on it. So I would think that if everything were healthy you should at least be getting close to 40 if not more. I have first hand seen one that was set ~50psi. That being said if all you can get is 36 you could just leave it there, those injectors may be fine running at that and while it is helpful to know the exact response and flow numbers at a given pressure it isnt mandatory as you build your own fuel map anyways. Given thats the top end of your fuel system output and the bottom end of acceptable pressure on the injectors though I think Jeffs point as to a safety margin may be something to be considered. Compromises like this are why i have moved more and more away from using a lot of the d-jet bits over the years. I can elaborate on the details a lot more if you like but that only matters if you are interested in changing your goals slightly. I get your current goals, I used to share them, and they are totally doable, just realize they involve compromises and one of those being running as optimally and reliably as it could, though no more so than running a d-jet system. You just wind up inheriting its short comings. |
| GregAmy |
Mar 5 2020, 06:18 AM
Eric, I'm actually starting to "write all this shit up" like I promised I would; I got into a writing spree yesterday and drafts are going up on my Blogger site now.
I'm looking for some time with a local DynaPack buddy, maybe get it in either this or next Saturday for a general baseline auto-tune and fiddling. Mostly depends on the weather (the 914 does not see the roads until all the salt crap is rained off.) Anyone know what AFRs these engines like to run at? Totally possible but you may be better off just running d-jet, l-jet, or possibly vanagon injectors, with load resistors at the stock pressures in that case. Eric and I discussed injectors. Eric took the "go with DJet" direction; I'm interested to see where he ends up. I, on the other hand, compared the cost of cleaning/testing my injectors ($125 incl shipping round-trip), the risk of one failing (a good used one $75-150), and the availability of replacements in the future (low, and getting worse). Coupled to the need for a resistor pack, I chose to replace all four injectors with FiveO's for ~$300 shipped (they offer 15% off coupons all the time). Same goes for a lot of the other D-Jet components. There's a strong argument for using parts readily available from FLAPS. All of my design decisions and results will be part of the Blogger writeup. QUOTE Not sure about the Bosch 69133 but the factory 2 ports are also supposed to have a built in over-pressure circuit. Hard to say what might be limiting your total pressure but that MSD FPR that is rated 36-42 PSI has the Bosch d-jet part number on it. ASSuming this is a consistent result - in other words, I have nothing "failing" - then I'm planning on tuning the car at 35psi. I can always re-tune to a higher pressure later. |
GregAmy D-Jet Fuel Pressure Regulator Mar 2 2020, 08:38 AM
914Sixer Stock set to run 28-30. In vapor lock areas up to... Mar 2 2020, 09:31 AM
JeffBowlsby 43.5 PSI is the conversion from 300kPA which is th... Mar 2 2020, 10:06 AM
GregAmy You sure your injectors are rated that high for in... Mar 2 2020, 10:41 AM
nordfisch
- You Posted: Injector Table
Hi Jeff,
the table... Mar 2 2020, 02:33 PM
JeffBowlsby As I thought...thats maximum flow, without a safet... Mar 2 2020, 11:45 AM
GregAmy
As I thought...thats maximum flow, without a safe... Mar 2 2020, 11:49 AM
914_teener
As I thought...thats maximum flow, without a saf... Mar 2 2020, 12:58 PM
GregAmy I'm confused. Flow and pressure are related h... Mar 2 2020, 01:19 PM
914_teener
I'm confused. Flow and pressure are related ... Mar 2 2020, 02:29 PM
ChrisFoley
no problem running these at 36psi and putting in... Mar 2 2020, 05:56 PM
GregAmy
Why even go up to 36? Calculate the flow at 30psi... Mar 2 2020, 06:54 PM
JamesM Was poking around a bit and and found these inject... Mar 3 2020, 11:50 PM
Bleyseng The Ljet has a variable fuel pressure regulator to... Mar 2 2020, 12:16 PM
JeffBowlsby Hi Norbert, thank you for the Bosch list its very ... Mar 2 2020, 05:48 PM
nordfisch
... The Weiss chart was a reference for me back t... Mar 3 2020, 02:00 PM
JamesM Higher pressure provides better fuel atomization, ... Mar 3 2020, 03:46 PM
914_teener
Higher pressure provides better fuel atomization,... Mar 3 2020, 05:40 PM
JamesM
I know some folds have done MS systems so maybe t... Mar 3 2020, 07:03 PM
914_teener
I know some folds have done MS systems so maybe ... Mar 3 2020, 08:17 PM
GregAmy The OP didn't say if he was going to retain th... Mar 3 2020, 08:36 PM
914_teener
The OP didn't say if he was going to retain t... Mar 3 2020, 08:41 PM
JamesM
Whole lotta dick-swinging around here and yet...n... Mar 3 2020, 11:09 PM
JeffBowlsby The concern about constant operation at maximum pr... Mar 3 2020, 04:30 PM
JamesM
The concern about constant operation at maximum p... Mar 3 2020, 07:52 PM
JamesM Just remembered I still have the paperwork for min... Mar 4 2020, 12:07 AM
JamesM
What should be the maximum capability of the stoc... Mar 4 2020, 01:39 AM
JamesM Hey, looky what I found....
https://www.injector... Mar 4 2020, 02:15 AM
JamesM Found another picture of the MSD 2222 where you ca... Mar 4 2020, 02:48 AM
GregAmy
Found another picture of the MSD 2222 where you c... Mar 5 2020, 10:08 AM
JamesM
Found another picture of the MSD 2222 where you ... Mar 5 2020, 06:30 PM
GregAmy Still has me curious why you are only seeing ~35.
... Mar 5 2020, 07:27 PM
barefoot Many years ago I had a project to design automotiv... Mar 4 2020, 06:19 AM
Montreal914
Though amazon is great and showed me this much c... Mar 5 2020, 12:05 AM
JamesM
[quote name='JamesM' post='2791279' date='Mar 3 2... Mar 5 2020, 09:38 AM
JeffBowlsby Check this.
"35 gal/hr"
Seems a bit ... Mar 5 2020, 08:14 AM
JamesM
Check this.
"35 gal/hr"
Seems a bit... Mar 5 2020, 09:51 AM
JeffBowlsby
Check this.
"35 gal/hr"
Seems a bit... Mar 5 2020, 11:03 AM
GregAmy It's not the pump. I went out there, jumped th... Mar 5 2020, 07:46 PM
ChrisFoley I have a few FPRs here. You're welcome to try ... Mar 6 2020, 06:38 AM
GregAmy Thank you sir!We're already overdue for a ... Mar 6 2020, 07:58 AM
JamesM
Thank you sir!We're already overdue for a... Mar 7 2020, 02:48 AM
Montreal914 Just catching up on the thread this morning.
Greg... Mar 7 2020, 11:03 AM
GregAmy Quick update... per Summit Racing, MSD has discont... Mar 9 2020, 11:40 AM
JamesM Didn't have time to tear into one this weekend... Mar 9 2020, 11:05 PM
JamesM Just did a bit more searching... this is an intere... Mar 10 2020, 12:09 AM
JamesM Knowing that 914 l-jet regulators are a direct swa... Mar 10 2020, 12:27 AM
JamesM This is interesting. In the latest bosch catalog ... Mar 10 2020, 01:22 AM
JamesM https://shopbhp.com/products/kit-car-fuel-p...ant=... Mar 10 2020, 01:49 AM
GregAmy May be more bad news for d-jet
Well crap.
I have ... Mar 10 2020, 06:45 AM
JamesM
Well crap.
I have... Mar 10 2020, 09:07 AM
ChrisFoley Bosch Fuel Pressure Regulator at Pelican Mar 9 2020, 02:26 PM
GregAmy And...they're out of stock. Refers me to ... Mar 9 2020, 04:21 PM
ChrisFoley You might want to start soaking the three used one... Mar 9 2020, 06:14 PM
GregAmy Here's a 3-bar one. eBay ad claims (I think) i... Mar 10 2020, 07:31 AM
GregAmy Am I correct in inferring his non-regulator one is... Mar 10 2020, 09:24 AM
JamesM
Am I correct in inferring his non-regulator one i... Mar 10 2020, 01:13 PM
GregAmy Mario's response, paraphrased:
This:
Univers... Mar 10 2020, 07:14 PM
ChrisFoley That's probably what Mario was thinking you wo... Mar 10 2020, 12:20 PM
GregAmy His stuff looks nice, but I sent an email him to f... Mar 10 2020, 12:59 PM
Montreal914 Seems like the way to go! Mar 10 2020, 09:50 PM
GregAmy Mario 3-bar FPR procured and installed. Shows 41.5... Mar 13 2020, 07:52 PM
ChrisFoley
Asking for a friend. :miles:
:shades2: Mar 14 2020, 05:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:55 PM |
