> Injectors to match TB on bigger engines
Literati914
post Mar 4 2020, 09:09 AM
I know a 2.1 throttle body from a vanagon is a popular option for say a 2270 build or better... and there does not seem to be a need for upgrading the stock 2.0L fuel injectors when using it BUT, since I need a set of injectors anyway, would the following be a good option? What would be the pro's/cons? :
https://www.gowesty.com/product/made-in-usa...ctor-bundle-?v=
djway
post Mar 5 2020, 10:26 PM
I have spent the past few days cleaning my stash of L Jet parts ranging from several 74 and 75 914 systems and some late Baywindow 2.0 bus systems.
The plenum's were all the same size but the late bus had the EGR tubes inside which I would assume should disrupt the air flow into the runners due to their location. If you are crafty it should be removable.
The 1.8 runners are narrower tubes until the end where they get larger for the sleeves. The 2.0 bus runners were the larger tube the entire length.
Now the difference in the brains with 6 pin not having an independent circuit for the air density resistor, although it is wired in and did affect my 74 when I cleaned the contact. The 75 7 pin does have the specific circuit wiring but I am not sure what smog programming may be in there. Then there is the 2.0 bus brain. I have read they are all interchangeable in a long thread on the samba and that the WOT circuit that is on some buses and not others does not seem to affect performance, on a bus.
I will be using the bus runners and the flat plenum, non 914 2.0. I will also adapt the 2.1 vanagon TB. Just need to decide if I should use the WOT/position switch circuit and which brain to use.
- Lo-Fi Version Time is now: 12th July 2025 - 11:58 AM
