> D-Jet Fuel Pressure Regulator, How high should it go?
GregAmy
post Mar 2 2020, 08:38 AM
What should be the maximum capability of the stock D-Jet pressure regulator? Mine only goes to 36.
If that's normal, is there another similar-format regulator that can go up to around 45psi?
Background: Microsquirt project. Was hoping to use the stock regulator, but now need something that I can easily mount in the same location, if possible. Injectors I'm using are rated at 43.5psi.
Discuss!
GregAmy
post Mar 6 2020, 07:58 AM
Thank you sir!We're already overdue for a beer visit. I may pass by tomorrow if you're in.
Here's some docs I found when I was going through paperwork. The injectors should be OK at higher pressures. Just not clear where I *should* run them. I clearly do not need the flow rate at higher pressure, but I wonder if reducing the duty cycle improved efficiency. I wonder if I'll even notice a difference at all by bothering to go over 35psi.
Attached File(s)
GregAmy   D-Jet Fuel Pressure Regulator   Mar 2 2020, 08:38 AM
914Sixer   Stock set to run 28-30. In vapor lock areas up to...   Mar 2 2020, 09:31 AM
JeffBowlsby   43.5 PSI is the conversion from 300kPA which is th...   Mar 2 2020, 10:06 AM
GregAmy   You sure your injectors are rated that high for in...   Mar 2 2020, 10:41 AM
nordfisch   - You Posted: Injector Table Hi Jeff, the table...   Mar 2 2020, 02:33 PM
JeffBowlsby   As I thought...thats maximum flow, without a safet...   Mar 2 2020, 11:45 AM
GregAmy   As I thought...thats maximum flow, without a safe...   Mar 2 2020, 11:49 AM
914_teener   As I thought...thats maximum flow, without a saf...   Mar 2 2020, 12:58 PM
GregAmy   I'm confused. Flow and pressure are related h...   Mar 2 2020, 01:19 PM
914_teener   I'm confused. Flow and pressure are related ...   Mar 2 2020, 02:29 PM
ChrisFoley   no problem running these at 36psi and putting in...   Mar 2 2020, 05:56 PM
GregAmy   Why even go up to 36? Calculate the flow at 30psi...   Mar 2 2020, 06:54 PM
JamesM   Was poking around a bit and and found these inject...   Mar 3 2020, 11:50 PM
Bleyseng   The Ljet has a variable fuel pressure regulator to...   Mar 2 2020, 12:16 PM
JeffBowlsby   Hi Norbert, thank you for the Bosch list its very ...   Mar 2 2020, 05:48 PM
nordfisch   ... The Weiss chart was a reference for me back t...   Mar 3 2020, 02:00 PM
JamesM   Higher pressure provides better fuel atomization, ...   Mar 3 2020, 03:46 PM
914_teener   Higher pressure provides better fuel atomization,...   Mar 3 2020, 05:40 PM
JamesM   I know some folds have done MS systems so maybe t...   Mar 3 2020, 07:03 PM
914_teener   I know some folds have done MS systems so maybe ...   Mar 3 2020, 08:17 PM
GregAmy   The OP didn't say if he was going to retain th...   Mar 3 2020, 08:36 PM
914_teener   The OP didn't say if he was going to retain t...   Mar 3 2020, 08:41 PM
JamesM   Whole lotta dick-swinging around here and yet...n...   Mar 3 2020, 11:09 PM
JeffBowlsby   The concern about constant operation at maximum pr...   Mar 3 2020, 04:30 PM
JamesM   The concern about constant operation at maximum p...   Mar 3 2020, 07:52 PM
JamesM   Just remembered I still have the paperwork for min...   Mar 4 2020, 12:07 AM
JamesM   What should be the maximum capability of the stoc...   Mar 4 2020, 01:39 AM
JamesM   Hey, looky what I found.... https://www.injector...   Mar 4 2020, 02:15 AM
JamesM   Found another picture of the MSD 2222 where you ca...   Mar 4 2020, 02:48 AM
GregAmy   Found another picture of the MSD 2222 where you c...   Mar 5 2020, 10:08 AM
JamesM   Found another picture of the MSD 2222 where you ...   Mar 5 2020, 06:30 PM
GregAmy   Still has me curious why you are only seeing ~35. ...   Mar 5 2020, 07:27 PM
GregAmy   Since we're going deeper into the design... A...   Mar 4 2020, 06:19 AM
JamesM   Since we're going deeper into the design... ...   Mar 5 2020, 12:29 AM
GregAmy   Eric, I'm actually starting to "write all...   Mar 5 2020, 06:18 AM
barefoot   Many years ago I had a project to design automotiv...   Mar 4 2020, 06:19 AM
Montreal914   Though amazon is great and showed me this much c...   Mar 5 2020, 12:05 AM
JamesM   [quote name='JamesM' post='2791279' date='Mar 3 2...   Mar 5 2020, 09:38 AM
JeffBowlsby   Check this. "35 gal/hr" Seems a bit ...   Mar 5 2020, 08:14 AM
JamesM   Check this. "35 gal/hr" Seems a bit...   Mar 5 2020, 09:51 AM
JeffBowlsby   Check this. "35 gal/hr" Seems a bit...   Mar 5 2020, 11:03 AM
GregAmy   It's not the pump. I went out there, jumped th...   Mar 5 2020, 07:46 PM
ChrisFoley   I have a few FPRs here. You're welcome to try ...   Mar 6 2020, 06:38 AM
GregAmy   Thank you sir!We're already overdue for a ...   Mar 6 2020, 07:58 AM
JamesM   Thank you sir!We're already overdue for a...   Mar 7 2020, 02:48 AM
Montreal914   Just catching up on the thread this morning. Greg...   Mar 7 2020, 11:03 AM
GregAmy   Quick update... per Summit Racing, MSD has discont...   Mar 9 2020, 11:40 AM
JamesM   Didn't have time to tear into one this weekend...   Mar 9 2020, 11:05 PM
JamesM   Just did a bit more searching... this is an intere...   Mar 10 2020, 12:09 AM
JamesM   Knowing that 914 l-jet regulators are a direct swa...   Mar 10 2020, 12:27 AM
JamesM   This is interesting. In the latest bosch catalog ...   Mar 10 2020, 01:22 AM
JamesM   https://shopbhp.com/products/kit-car-fuel-p...ant=...   Mar 10 2020, 01:49 AM
GregAmy   May be more bad news for d-jet Well crap. I have ...   Mar 10 2020, 06:45 AM
JamesM   May be more bad news for d-jet Well crap. I have...   Mar 10 2020, 09:07 AM
ChrisFoley   Bosch Fuel Pressure Regulator at Pelican   Mar 9 2020, 02:26 PM
GregAmy   And...they're out of stock. Refers me to ...   Mar 9 2020, 04:21 PM
ChrisFoley   You might want to start soaking the three used one...   Mar 9 2020, 06:14 PM
GregAmy   Here's a 3-bar one. eBay ad claims (I think) i...   Mar 10 2020, 07:31 AM
GregAmy   Am I correct in inferring his non-regulator one is...   Mar 10 2020, 09:24 AM
JamesM   Am I correct in inferring his non-regulator one i...   Mar 10 2020, 01:13 PM
GregAmy   Mario's response, paraphrased: This: Univers...   Mar 10 2020, 07:14 PM
ChrisFoley   That's probably what Mario was thinking you wo...   Mar 10 2020, 12:20 PM
GregAmy   His stuff looks nice, but I sent an email him to f...   Mar 10 2020, 12:59 PM
Montreal914   Seems like the way to go!   Mar 10 2020, 09:50 PM
GregAmy   Mario 3-bar FPR procured and installed. Shows 41.5...   Mar 13 2020, 07:52 PM
ChrisFoley   Asking for a friend. :miles: :shades2:   Mar 14 2020, 05:49 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:50 PM
