| tinker_n_smoke |
Mar 8 2020, 08:09 PM
Newbie ![]() Group: Members Posts: 16 Joined: 8-March 20 From: vancouver Member No.: 24,003 Region Association: Canada |
(IMG:style_emoticons/default/WTF.gif)
So I am a new 914 owner ( 1973) - car is running, but the clutch will not engage. Last owner said they thought the linkage was broken - but in looking under the car, the rod is moving just fine from shifter back to transmission. As I am poking around today I notice this cable end out near the rear / firewall. Is this my clutch cable? I think it is, but confused where the rest ended up.. and... where should I look/ repair for this? THANK YOU! ![]() |
| Mikey914 |
Mar 8 2020, 11:27 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
The cable you should be looking at for the clutch is this one. The spacer shown is typically through the engine mount bar hole, but it would work without it being in there. It attaches to a housing that has a pulley that looks like this
Attached thumbnail(s) Attached image(s)
tinker_n_smoke newbie / clutch? HELP? Mar 8 2020, 08:09 PM
DickSteinkamp Won't engage or won't disengage? Mar 8 2020, 09:18 PM
tinker_n_smoke It will not engage. The movement on the stick / s... Mar 8 2020, 09:51 PM
tinker_n_smoke It will not engage. The movement on the stick / s... Mar 8 2020, 09:52 PM
PanelBilly That’s the cable for the heat Mar 8 2020, 09:30 PM
tinker_n_smoke thank you. good to know.
That’s the cable for t... Mar 8 2020, 09:52 PM
cuddy_k :agree: That's one of the heater duct pull cab... Mar 8 2020, 09:57 PM
Highland I think that long grommet on your clutch cable (ag... Mar 8 2020, 10:02 PM
Mikey914 You can have someone depress the clutch and it sho... Mar 8 2020, 11:31 PM
DickSteinkamp I'm still confused (as usual)
You ENGAGE the ... Mar 9 2020, 08:53 AM
Tbrown4x4 1. You push the clutch pedal down to disengage th... Mar 9 2020, 09:31 AM
tinker_n_smoke Thank you!! I tried best to explain below... Mar 9 2020, 06:11 PM
tinker_n_smoke OK, so I have looked at the pully/ clutch cable. W... Mar 9 2020, 01:23 PM
tinker_n_smoke grinding noise / video::
https://youtu.be/VP7bdVLE... Mar 9 2020, 04:27 PM
ndfrigi
https://youtu.be/VP7bdVL... Mar 9 2020, 05:04 PM
JOEPROPER Hard to tell what's going on there by the vide... Mar 9 2020, 05:01 PM
tinker_n_smoke appreciate the concerns for sure! I'm New... Mar 9 2020, 06:05 PM
JOEPROPER Are the wheels off the ground and is the car stabl... Mar 9 2020, 05:03 PM
tinker_n_smoke car is up / have the 4 wheels sitting on an old se... Mar 9 2020, 06:02 PM
dr914@autoatlanta.com call me tomorrow and I will guide you through it
... Mar 9 2020, 05:43 PM
tinker_n_smoke amazing! Thank you
call me tomorrow and I w... Mar 9 2020, 06:00 PM
tinker_n_smoke Hi George - I got called in to work - will for sur... Mar 11 2020, 02:37 PM
bbrock I think the grinding is just because the clutch is... Mar 9 2020, 06:01 PM
injunmort check your shifter rod bushings and linkage alignm... Mar 9 2020, 06:27 PM
tinker_n_smoke link
Clip under car. looks like I am also missing... Mar 10 2020, 01:43 PM
ndfrigi
link
Clip under car. looks like I am also missin... Mar 10 2020, 01:53 PM
tinker_n_smoke ?
[quote name='tinker_n_smoke' post='2792975' da... Mar 10 2020, 01:59 PM
mrholland2 You should not be able to move that with your fing... Mar 10 2020, 04:01 PM
cuddy_k Wow. Looks like you're missing some hardware. ... Mar 10 2020, 05:08 PM
DickSteinkamp I'm trying to figure out how you could shift i... Mar 10 2020, 07:58 PM
tinker_n_smoke I had the cable/assembly connected before, disconn... Mar 10 2020, 08:47 PM
DickSteinkamp
I had the cable/assembly connected before, discon... Mar 10 2020, 09:09 PM
rhodyguy The wing nut is wrong. The blob behind it is weird... Mar 10 2020, 09:28 PM
falcor75 Your pressure plate is toast or not there at all. ... Mar 11 2020, 12:12 AM
Mikey914 Good news is it looks like a pressure plate issue ... Mar 11 2020, 01:00 AM
Tbrown4x4 Lots of unusual stuff here. I suppose it's pos... Mar 11 2020, 06:45 AM
rhodyguy :agree: right. Small ball cup bushing, perhaps the... Mar 11 2020, 06:58 AM
Mikey914 My money is on the pressure plate. I know I have r... Mar 11 2020, 10:26 AM
sixnotfour :wttc:
Add Clutch Tube Broke Loose to the List...... Mar 11 2020, 10:52 AM
tinker_n_smoke Started with looking at the clutch tube - suprisin... Mar 11 2020, 01:05 PM
IronHillRestorations First thing I would do is make sure you've got... Mar 11 2020, 05:07 PM
DickSteinkamp
Not to send you chasing down another rabbit hol... Mar 11 2020, 06:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:21 AM |
