> newbie / clutch? HELP?, Not sure what to do here...
tinker_n_smoke
post Mar 8 2020, 08:09 PM
(IMG:style_emoticons/default/WTF.gif)
So I am a new 914 owner ( 1973) - car is running, but the clutch will not engage. Last owner said they thought the linkage was broken - but in looking under the car, the rod is moving just fine from shifter back to transmission.
As I am poking around today I notice this cable end out near the rear / firewall.
Is this my clutch cable? I think it is, but confused where the rest ended up.. and... where should I look/ repair for this?
THANK YOU!
Tbrown4x4
post Mar 9 2020, 09:31 AM
1. You push the clutch pedal down to disengage the engine from the transmission. I hear that mistake a lot.
The natural position of the clutch pressure plate is clamping the clutch disc. The cable (via the clutch pedal) pulls back on the clutch release arm, which pivots on a ball and pushes forward on the pressure plate springs to release the clutch disc.
The flywheel and the pressure plate rotate with the engine. The clutch disc is splined to the transmission input shaft. When your foot is off the clutch pedal, all 3 are clamped together as one, and the engine drives the input shaft. When you push the pedal down, the pressure plate releases its grip on the disc, and you can shift gears, or sit at a stop with the engine running.
I hope that's not too long-winded. Now. What EXACTLY is your car doing?
No gears? Grinding gears? Or car will not move?
tinker_n_smoke   newbie / clutch? HELP?   Mar 8 2020, 08:09 PM
DickSteinkamp   Won't engage or won't disengage?   Mar 8 2020, 09:18 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:51 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:52 PM
PanelBilly   That’s the cable for the heat   Mar 8 2020, 09:30 PM
tinker_n_smoke   thank you. good to know. That’s the cable for t...   Mar 8 2020, 09:52 PM
cuddy_k   :agree: That's one of the heater duct pull cab...   Mar 8 2020, 09:57 PM
Highland   I think that long grommet on your clutch cable (ag...   Mar 8 2020, 10:02 PM
Mikey914   The cable you should be looking at for the clutch ...   Mar 8 2020, 11:27 PM
Mikey914   You can have someone depress the clutch and it sho...   Mar 8 2020, 11:31 PM
DickSteinkamp   I'm still confused (as usual) You ENGAGE the ...   Mar 9 2020, 08:53 AM
Tbrown4x4   1. You push the clutch pedal down to disengage th...   Mar 9 2020, 09:31 AM
tinker_n_smoke   Thank you!! I tried best to explain below...   Mar 9 2020, 06:11 PM
tinker_n_smoke   OK, so I have looked at the pully/ clutch cable. W...   Mar 9 2020, 01:23 PM
tinker_n_smoke   grinding noise / video:: https://youtu.be/VP7bdVLE...   Mar 9 2020, 04:27 PM
ndfrigi   grinding noise / video:: https://youtu.be/VP7bdVL...   Mar 9 2020, 05:04 PM
JOEPROPER   Hard to tell what's going on there by the vide...   Mar 9 2020, 05:01 PM
tinker_n_smoke   appreciate the concerns for sure! I'm New...   Mar 9 2020, 06:05 PM
JOEPROPER   Are the wheels off the ground and is the car stabl...   Mar 9 2020, 05:03 PM
tinker_n_smoke   car is up / have the 4 wheels sitting on an old se...   Mar 9 2020, 06:02 PM
dr914@autoatlanta.com   call me tomorrow and I will guide you through it ...   Mar 9 2020, 05:43 PM
tinker_n_smoke   amazing! Thank you call me tomorrow and I w...   Mar 9 2020, 06:00 PM
tinker_n_smoke   Hi George - I got called in to work - will for sur...   Mar 11 2020, 02:37 PM
bbrock   I think the grinding is just because the clutch is...   Mar 9 2020, 06:01 PM
injunmort   check your shifter rod bushings and linkage alignm...   Mar 9 2020, 06:27 PM
tinker_n_smoke   link Clip under car. looks like I am also missing...   Mar 10 2020, 01:43 PM
ndfrigi   link Clip under car. looks like I am also missin...   Mar 10 2020, 01:53 PM
tinker_n_smoke   ? [quote name='tinker_n_smoke' post='2792975' da...   Mar 10 2020, 01:59 PM
mrholland2   You should not be able to move that with your fing...   Mar 10 2020, 04:01 PM
cuddy_k   Wow. Looks like you're missing some hardware. ...   Mar 10 2020, 05:08 PM
DickSteinkamp   I'm trying to figure out how you could shift i...   Mar 10 2020, 07:58 PM
tinker_n_smoke   I had the cable/assembly connected before, disconn...   Mar 10 2020, 08:47 PM
DickSteinkamp   I had the cable/assembly connected before, discon...   Mar 10 2020, 09:09 PM
rhodyguy   The wing nut is wrong. The blob behind it is weird...   Mar 10 2020, 09:28 PM
falcor75   Your pressure plate is toast or not there at all. ...   Mar 11 2020, 12:12 AM
Mikey914   Good news is it looks like a pressure plate issue ...   Mar 11 2020, 01:00 AM
Tbrown4x4   Lots of unusual stuff here. I suppose it's pos...   Mar 11 2020, 06:45 AM
rhodyguy   :agree: right. Small ball cup bushing, perhaps the...   Mar 11 2020, 06:58 AM
Mikey914   My money is on the pressure plate. I know I have r...   Mar 11 2020, 10:26 AM
sixnotfour   :wttc: Add Clutch Tube Broke Loose to the List......   Mar 11 2020, 10:52 AM
tinker_n_smoke   Started with looking at the clutch tube - suprisin...   Mar 11 2020, 01:05 PM
IronHillRestorations   First thing I would do is make sure you've got...   Mar 11 2020, 05:07 PM
DickSteinkamp   Not to send you chasing down another rabbit hol...   Mar 11 2020, 06:20 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:21 AM
