| jaredmcginness |
Mar 9 2020, 12:23 PM
... ![]() ![]() ![]() Group: Members Posts: 510 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region
Hey guys,
I figured I would make a build here. I am very active on the facebook group and have received some great feedback and help from the guys over there. I will try and remeber to update this as I complete some work. I'm in my late 20's and have wanted a 914 for a long while now. I've been through 11 or 12 VW's water and aircooled - Rabbits, Caddys, Beetle, etc... so it's natural progression I suppose. I found this car in Louisville and towed it home last summer. A friend looked at it for me. Gave me the OK, said there was minor rust, but a solid project. I paid for the car, and drove out that weekend. Upon arrival I found there to be a pretty severe case of rust... I stored the car the rest of the year - bit the bullet and decided to go to town on the structural repairs. It is the color and the car I want. I work in fabrication by trade, so I am not too scared to take on this project. I will not be driving the car until I feel it’s solid. I am cutting some corners - depending on how you look at it. This is a budget build. But I will be using as many replacement parts (AA and RD) as I can. Without removing too much of the car. (IMG:style_emoticons/default/beer3.gif) Car: 12/70 vin. Added to database. Off the road since 1998. 1.7 gunky motor. Toasty interior. 70k miles shown, iirc. So probably 170k Came with late style black adjustable seats. Plan: Fix structural rust so I can drive the car ASAP I’d like to keep original paint (too late) Fix as much rust as I can. (Hell hole, shelf, passenger long, floors) Drop in replacement motor Run new brake and fuel lines 5lug swap. 2.0 down the road? So what's been accomplished? As of July/2020 Structural rust fully repaired. Top end of 1911cc is done, bottom end in the works. 5 Lug swap Replaced all interior components. Tail and window rust, outer body rust Side markers deleted. 924 Retractable seat belts. Drank sh*tload of beer. Spent a good deal of cash. tons of other little things. So much stuff! This will be a cars and coffee cruiser, not a concour restoration (sorry!) I just want to drive MY 914! The car as I found it: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779074.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779075.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779364.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779365.2.jpg) Quick Buff: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779365.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779365.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583779365.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583780005.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-23209-1583780006.2.jpg) |
| Cairo94507 |
Mar 9 2020, 01:20 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,803 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
(IMG:style_emoticons/default/welcome.png) Great color and a good project.
Before you put that motor in you may want to check all of the suspension mounting points and the hell hole (area below the factor battery location). Repairs are easier to handle with no engine/transaxle installed. Of course you may as well replace the fuel lines in the tunnel if they are still plastic and upgrade to the stainless steel from Tangerine Racing or others. Pull the fuel tank and have that boiled out and perhaps coated and replace the remaining rubber fuel lines. Clean all of the body grounds on the car. Then rebuild the brakes calipers, replace the flexible lines and flush the entire system. That should keep you bust for a bit. These cars are a blast to drive but we always want to make sure the car itself is safe to dive as they are now 50 years old. Good luck, (IMG:style_emoticons/default/beerchug.gif) Michael |
| jaredmcginness |
Mar 9 2020, 02:43 PM
(IMG:style_emoticons/default/welcome.png) Great color and a good project. Before you put that motor in you may want to check all of the suspension mounting points and the hell hole (area below the factor battery location). Repairs are easier to handle with no engine/transaxle installed. Of course you may as well replace the fuel lines in the tunnel if they are still plastic and upgrade to the stainless steel from Tangerine Racing or others. Pull the fuel tank and have that boiled out and perhaps coated and replace the remaining rubber fuel lines. Clean all of the body grounds on the car. Then rebuild the brakes calipers, replace the flexible lines and flush the entire system. That should keep you bust for a bit. These cars are a blast to drive but we always want to make sure the car itself is safe to dive as they are now 50 years old. Good luck, (IMG:style_emoticons/default/beerchug.gif) Michael Thanks for the good tips. I would say I am well versed in the lingo and parts of these cars - I’ve been lurking you guys for 5+ years. I will be running all new fuel lines, fixing the hell hole, 5 lug swap (new brakes) etc. |
jaredmcginness Irish Green '71 "Resto" Mar 9 2020, 12:23 PM
AZBanks :wttc: Looking forward to seeing the progress on y... Mar 9 2020, 12:37 PM
billh1963
Hey guys,
I figured i would make a build here. I... Mar 9 2020, 12:37 PM
jaredmcginness As requested, as for the ugly...
http://www.914w... Mar 9 2020, 12:50 PM
TargaToy Welcome to the World!!!
As you know, ... Mar 9 2020, 12:53 PM
jaredmcginness My dad and I picked up a running 1.7 for next to n... Mar 9 2020, 12:56 PM
jaredmcginness http://www.914world.com/bbs2/uploads_offsite/i.img... Mar 9 2020, 01:24 PM
JOEPROPER :wttc:
Looks like a lot of work :sawzall: :welde... Mar 9 2020, 01:40 PM
mbseto Welcome! Good start, will be watching with in... Mar 9 2020, 01:48 PM
buck toenges Rolling Rock and Irish green. Good Choice! Mar 9 2020, 03:53 PM
jaredmcginness Hey guys,
Another little update. Trying to tackle... Mar 11 2020, 06:53 AM
jaredmcginness Quickie test fit of the outer clamshell. I wanted ... Mar 11 2020, 07:16 AM
dt4 Great skills and work levels Mar 11 2020, 07:56 AM
jaredmcginness Here's a list of some of the other things I ha... Mar 11 2020, 10:01 AM
jaredmcginness Not related to fixing the car... but part of the b... Mar 13 2020, 05:28 AM
Targa70 Jared, you have mad skills. My hat is off to you ... Mar 13 2020, 05:40 AM
jaredmcginness
Jared, you have mad skills. My hat is off to you... Mar 13 2020, 06:07 AM
jagalyn Wow... nice job so far. Keep it up!!! Mar 13 2020, 06:20 AM
jaredmcginness
Wow... nice job so far. Keep it up!!... Mar 13 2020, 10:49 AM
jaredmcginness Something else I completed.
The frunk handle was ... Mar 13 2020, 10:44 AM
Jamie
The frunk handle was... Mar 14 2020, 07:29 PM
bbrock Nice job on the handle patch :trophy: I think that... Mar 13 2020, 11:56 AM
jaredmcginness
Nice job on the handle patch :trophy: I think tha... Mar 13 2020, 12:14 PM
Targa70 Hey Jared, I'm not up in NOVA. I hang my hat ... Mar 13 2020, 12:26 PM
jaredmcginness
Hey Jared, I'm not up in NOVA. I hang my hat... Mar 13 2020, 01:14 PM
kroelofsen :bump: Thats very nice work, great speed, will wat... Mar 13 2020, 12:47 PM
bkrantz Keep up the good work--and the optimism. That... Mar 13 2020, 09:19 PM
jaredmcginness
Keep up the good work--and the optimism. That... Mar 14 2020, 03:14 PM
bbrock
...We'll never see it again. Right?
... Righ... Mar 14 2020, 06:42 PM
mepstein Actually very common. Dirt, debris, mouse nests, e... Mar 14 2020, 08:00 PM
jaredmcginness
Actually very common. Dirt, debris, mouse nests, ... Mar 15 2020, 06:18 PM
horizontally-opposed Nice work—great to see someone in their 20s work... Mar 15 2020, 06:34 PM
jaredmcginness
Nice
Those Fuchs were a great score—there... Mar 15 2020, 06:43 PM
jaredmcginness Hey all,
Hope everyone is doing OK with this Covi... Mar 19 2020, 07:26 PM
BeatNavy Wow, I just noticed this thread. You're doing... Mar 20 2020, 05:53 AM
AZBanks Instead of body filler, I would spend a little mor... Mar 20 2020, 06:12 PM
bbrock Nice work! :welder: :smash: It isn't a ba... Mar 20 2020, 06:41 PM
jaredmcginness
Wow, I just noticed this thread. You're doin... Mar 20 2020, 07:19 PM
bbrock Just to be clear. I agree with Rob there is no sh... Mar 20 2020, 07:28 PM
jaredmcginness
Just to be clear. I agree with Rob there is no s... Mar 20 2020, 07:45 PM
jaredmcginness Posted and forgot to add the work I accomplished t... Mar 20 2020, 07:37 PM
jaredmcginness Weekend update:
Part 1:
Decided to go at the hol... Mar 22 2020, 10:54 AM
bbrock Pure inspiration!!! I love watching t... Mar 22 2020, 01:09 PM
Chief Great work! And loving Oatmeal!! Mar 22 2020, 01:15 PM
jaredmcginness Thanks guys!
Sunday project. My girlfriend an... Mar 23 2020, 10:03 AM
BeatNavy Those Fuchs look great. What did you do to the pet... Mar 23 2020, 10:41 AM
jaredmcginness
Those Fuchs look great. What did you do to the pe... Mar 23 2020, 10:53 AM
PCH Great work Jared! Love watching your car progr... Mar 23 2020, 01:17 PM
Cairo94507 You are doing a nice job and that 914 is going to ... Mar 23 2020, 01:44 PM
jaredmcginness Tuesday update.
I'm ready to weld the sill b... Mar 24 2020, 06:53 PM
bkrantz Nice progress. And that jamb section could have a... Mar 24 2020, 08:02 PM
StarBear
Nice progress. And that jamb section could have ... Mar 27 2020, 08:24 AM
bbrock Of all the horrors I witnessed on my car, I don... Mar 24 2020, 09:20 PM
jaredmcginness Edit: Seriously thanks for the kind words guys, it... Mar 27 2020, 06:23 AM
JOEPROPER A lot of patience and talent. I wish I had nerve ... Mar 27 2020, 06:45 AM
DRPHIL914 thanks for keeping us updated on your project, its... Mar 27 2020, 07:15 AM
AZBanks Really enjoying seeing your progress on this proje... Mar 27 2020, 11:30 AM
pete-stevers Great thread! Keep up the great work!... Mar 27 2020, 12:20 PM
jaredmcginness
A lot of patience and talent. I wish I had nerve... Mar 28 2020, 08:44 PM
jaredmcginness Happy Saturday,
Lets finish up this passenger sid... Mar 28 2020, 09:08 PM
bbrock
Sorry to let down any folks, I know this is not ... Mar 29 2020, 08:52 AM
JOEPROPER
Sorry to let down any folks, I know this is not... Mar 29 2020, 11:36 AM
JOEPROPER :trophy: Mar 28 2020, 09:40 PM
StarBear A champion! Loving this thread - better than a... Mar 29 2020, 09:47 AM
jaredmcginness
To the contrary! You are doing what is nee... Mar 29 2020, 06:18 PM
bkrantz You are a better (tougher) man than me, getting al... Mar 29 2020, 08:18 PM
BeatNavy You're rocking and rolling! I think it to... Mar 30 2020, 04:07 AM
jaredmcginness
You are a better (tougher) man than me, getting a... Mar 30 2020, 06:39 AM
BeatNavy
One of my personal faves is, [i]"If the mini... Mar 30 2020, 08:01 AM
bbrock Add me to those amazed at your ability to tackle t... Mar 30 2020, 07:57 AM
jaredmcginness Took Monday night off to hang out and not do any w... Apr 1 2020, 08:29 AM
BeatNavy
I believe this is the commonly broken, brazed are... Apr 1 2020, 09:36 AM
bbrock
I believe this is the commonly broken, brazed ar... Apr 2 2020, 08:11 AM
JOEPROPER Man, you're a handy guy to have around. :pop... Apr 1 2020, 08:56 AM
bkrantz
Got the center floor out - oh how i hate laying... Apr 1 2020, 08:16 PM
jaredmcginness
Where's the required mouse nest?
There we... Apr 2 2020, 07:43 AM
Here is today's diary entry. :smas... Apr 4 2020, 04:35 PM
BeatNavy
Ugly, but honest.
:) Honest is better than pr... Apr 4 2020, 05:13 PM
jaredmcginness Weekend Update:
Spent about 12 hours outside Frid... Apr 6 2020, 11:01 AM
bkrantz Congrats on that milestone. I had my door on for ... Apr 6 2020, 09:02 PM
jaredmcginness More prep and a few questions!
Installing my ... Apr 9 2020, 05:43 AM
BeatNavy Nice Jared. I like how you have the body dimensio... Apr 9 2020, 07:07 AM
jaredmcginness
Not in my "Top 25 PITA" tasks on my tee... Apr 9 2020, 12:46 PM
Finished up the passenger floor today.... Apr 11 2020, 06:57 PM
tygaboy Us old guys call what you're doing "kicki... Apr 12 2020, 04:43 PM
Cairo94507 Chris- Are you sure you were never a LEO? That wa... Apr 13 2020, 08:22 AM
jaredmcginness Hey Ladies,
Something to look at on your lunch br... Apr 14 2020, 07:17 PM
bbrock
And compared to what I had in there... Yikes.
ht... Apr 14 2020, 08:51 PM
jaredmcginness
Okay, now I see why you cut those cross member ... Apr 15 2020, 06:40 AM
JOEPROPER Go get the argon tank filled so we can continue to... Apr 15 2020, 08:03 AM
Baker17 Got a 1973 1.7 L by the side of the house just wai... Apr 15 2020, 03:15 PM
bbrock
I know, you must be asking yourself why I even bo... Apr 15 2020, 03:58 PM
jaredmcginness
Got a 1973 1.7 L by the side of the house just wa... Apr 16 2020, 06:44 AM
jaredmcginness 95% finished the floor up.
All the spot welds ar... Apr 17 2020, 06:01 AM
DRPHIL914
All the spot welds a... Apr 17 2020, 07:32 AM
bbrock
looks good on the floor way to go!! BUTâ€... Apr 17 2020, 07:42 AM
BeatNavy Man, all that new steel looks GOOD! :trophy:... Apr 17 2020, 06:17 AM
jaredmcginness
looks good on the floor way to go!! BUTâ... Apr 17 2020, 07:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 26th November 2026 - 03:18 PM |
