| tinker_n_smoke |
Mar 8 2020, 08:09 PM
Newbie ![]() Group: Members Posts: 16 Joined: 8-March 20 From: vancouver Member No.: 24,003 Region Association: Canada |
(IMG:style_emoticons/default/WTF.gif)
So I am a new 914 owner ( 1973) - car is running, but the clutch will not engage. Last owner said they thought the linkage was broken - but in looking under the car, the rod is moving just fine from shifter back to transmission. As I am poking around today I notice this cable end out near the rear / firewall. Is this my clutch cable? I think it is, but confused where the rest ended up.. and... where should I look/ repair for this? THANK YOU! ![]() |
| tinker_n_smoke |
Mar 9 2020, 04:27 PM
tinker_n_smoke newbie / clutch? HELP? Mar 8 2020, 08:09 PM
DickSteinkamp Won't engage or won't disengage? Mar 8 2020, 09:18 PM
tinker_n_smoke It will not engage. The movement on the stick / s... Mar 8 2020, 09:51 PM
tinker_n_smoke It will not engage. The movement on the stick / s... Mar 8 2020, 09:52 PM
PanelBilly That’s the cable for the heat Mar 8 2020, 09:30 PM
tinker_n_smoke thank you. good to know.
That’s the cable for t... Mar 8 2020, 09:52 PM
cuddy_k :agree: That's one of the heater duct pull cab... Mar 8 2020, 09:57 PM
Highland I think that long grommet on your clutch cable (ag... Mar 8 2020, 10:02 PM
Mikey914 The cable you should be looking at for the clutch ... Mar 8 2020, 11:27 PM
Mikey914 You can have someone depress the clutch and it sho... Mar 8 2020, 11:31 PM
DickSteinkamp I'm still confused (as usual)
You ENGAGE the ... Mar 9 2020, 08:53 AM
Tbrown4x4 1. You push the clutch pedal down to disengage th... Mar 9 2020, 09:31 AM
tinker_n_smoke Thank you!! I tried best to explain below... Mar 9 2020, 06:11 PM
tinker_n_smoke OK, so I have looked at the pully/ clutch cable. W... Mar 9 2020, 01:23 PM
ndfrigi
grinding noise / video::
https://youtu.be/VP7bdVL... Mar 9 2020, 05:04 PM
JOEPROPER Hard to tell what's going on there by the vide... Mar 9 2020, 05:01 PM
tinker_n_smoke appreciate the concerns for sure! I'm New... Mar 9 2020, 06:05 PM
JOEPROPER Are the wheels off the ground and is the car stabl... Mar 9 2020, 05:03 PM
tinker_n_smoke car is up / have the 4 wheels sitting on an old se... Mar 9 2020, 06:02 PM
dr914@autoatlanta.com call me tomorrow and I will guide you through it
... Mar 9 2020, 05:43 PM
tinker_n_smoke amazing! Thank you
call me tomorrow and I w... Mar 9 2020, 06:00 PM
tinker_n_smoke Hi George - I got called in to work - will for sur... Mar 11 2020, 02:37 PM
bbrock I think the grinding is just because the clutch is... Mar 9 2020, 06:01 PM
injunmort check your shifter rod bushings and linkage alignm... Mar 9 2020, 06:27 PM
tinker_n_smoke link
Clip under car. looks like I am also missing... Mar 10 2020, 01:43 PM
ndfrigi
link
Clip under car. looks like I am also missin... Mar 10 2020, 01:53 PM
tinker_n_smoke ?
[quote name='tinker_n_smoke' post='2792975' da... Mar 10 2020, 01:59 PM
mrholland2 You should not be able to move that with your fing... Mar 10 2020, 04:01 PM
cuddy_k Wow. Looks like you're missing some hardware. ... Mar 10 2020, 05:08 PM
DickSteinkamp I'm trying to figure out how you could shift i... Mar 10 2020, 07:58 PM
tinker_n_smoke I had the cable/assembly connected before, disconn... Mar 10 2020, 08:47 PM
DickSteinkamp
I had the cable/assembly connected before, discon... Mar 10 2020, 09:09 PM
rhodyguy The wing nut is wrong. The blob behind it is weird... Mar 10 2020, 09:28 PM
falcor75 Your pressure plate is toast or not there at all. ... Mar 11 2020, 12:12 AM
Mikey914 Good news is it looks like a pressure plate issue ... Mar 11 2020, 01:00 AM
Tbrown4x4 Lots of unusual stuff here. I suppose it's pos... Mar 11 2020, 06:45 AM
rhodyguy :agree: right. Small ball cup bushing, perhaps the... Mar 11 2020, 06:58 AM
Mikey914 My money is on the pressure plate. I know I have r... Mar 11 2020, 10:26 AM
sixnotfour :wttc:
Add Clutch Tube Broke Loose to the List...... Mar 11 2020, 10:52 AM
tinker_n_smoke Started with looking at the clutch tube - suprisin... Mar 11 2020, 01:05 PM
IronHillRestorations First thing I would do is make sure you've got... Mar 11 2020, 05:07 PM
DickSteinkamp
Not to send you chasing down another rabbit hol... Mar 11 2020, 06:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:20 AM |
