> newbie / clutch? HELP?, Not sure what to do here...
tinker_n_smoke
post Mar 8 2020, 08:09 PM
(IMG:style_emoticons/default/WTF.gif)
So I am a new 914 owner ( 1973) - car is running, but the clutch will not engage. Last owner said they thought the linkage was broken - but in looking under the car, the rod is moving just fine from shifter back to transmission.
As I am poking around today I notice this cable end out near the rear / firewall.
Is this my clutch cable? I think it is, but confused where the rest ended up.. and... where should I look/ repair for this?
THANK YOU!
dr914@autoatlanta.com
post Mar 9 2020, 05:43 PM
call me tomorrow and I will guide you through it
QUOTE(tinker_n_smoke @ Mar 8 2020, 07:09 PM) *
THANK YOU!
tinker_n_smoke   newbie / clutch? HELP?   Mar 8 2020, 08:09 PM
DickSteinkamp   Won't engage or won't disengage?   Mar 8 2020, 09:18 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:51 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:52 PM
PanelBilly   That’s the cable for the heat   Mar 8 2020, 09:30 PM
tinker_n_smoke   thank you. good to know. That’s the cable for t...   Mar 8 2020, 09:52 PM
cuddy_k   :agree: That's one of the heater duct pull cab...   Mar 8 2020, 09:57 PM
Highland   I think that long grommet on your clutch cable (ag...   Mar 8 2020, 10:02 PM
Mikey914   The cable you should be looking at for the clutch ...   Mar 8 2020, 11:27 PM
Mikey914   You can have someone depress the clutch and it sho...   Mar 8 2020, 11:31 PM
DickSteinkamp   I'm still confused (as usual) You ENGAGE the ...   Mar 9 2020, 08:53 AM
Tbrown4x4   1. You push the clutch pedal down to disengage th...   Mar 9 2020, 09:31 AM
tinker_n_smoke   Thank you!! I tried best to explain below...   Mar 9 2020, 06:11 PM
tinker_n_smoke   OK, so I have looked at the pully/ clutch cable. W...   Mar 9 2020, 01:23 PM
tinker_n_smoke   grinding noise / video:: https://youtu.be/VP7bdVLE...   Mar 9 2020, 04:27 PM
ndfrigi   grinding noise / video:: https://youtu.be/VP7bdVL...   Mar 9 2020, 05:04 PM
JOEPROPER   Hard to tell what's going on there by the vide...   Mar 9 2020, 05:01 PM
tinker_n_smoke   appreciate the concerns for sure! I'm New...   Mar 9 2020, 06:05 PM
JOEPROPER   Are the wheels off the ground and is the car stabl...   Mar 9 2020, 05:03 PM
tinker_n_smoke   car is up / have the 4 wheels sitting on an old se...   Mar 9 2020, 06:02 PM
dr914@autoatlanta.com   call me tomorrow and I will guide you through it ...   Mar 9 2020, 05:43 PM
tinker_n_smoke   amazing! Thank you call me tomorrow and I w...   Mar 9 2020, 06:00 PM
tinker_n_smoke   Hi George - I got called in to work - will for sur...   Mar 11 2020, 02:37 PM
bbrock   I think the grinding is just because the clutch is...   Mar 9 2020, 06:01 PM
injunmort   check your shifter rod bushings and linkage alignm...   Mar 9 2020, 06:27 PM
tinker_n_smoke   link Clip under car. looks like I am also missing...   Mar 10 2020, 01:43 PM
ndfrigi   link Clip under car. looks like I am also missin...   Mar 10 2020, 01:53 PM
tinker_n_smoke   ? [quote name='tinker_n_smoke' post='2792975' da...   Mar 10 2020, 01:59 PM
mrholland2   You should not be able to move that with your fing...   Mar 10 2020, 04:01 PM
cuddy_k   Wow. Looks like you're missing some hardware. ...   Mar 10 2020, 05:08 PM
DickSteinkamp   I'm trying to figure out how you could shift i...   Mar 10 2020, 07:58 PM
tinker_n_smoke   I had the cable/assembly connected before, disconn...   Mar 10 2020, 08:47 PM
DickSteinkamp   I had the cable/assembly connected before, discon...   Mar 10 2020, 09:09 PM
rhodyguy   The wing nut is wrong. The blob behind it is weird...   Mar 10 2020, 09:28 PM
falcor75   Your pressure plate is toast or not there at all. ...   Mar 11 2020, 12:12 AM
Mikey914   Good news is it looks like a pressure plate issue ...   Mar 11 2020, 01:00 AM
Tbrown4x4   Lots of unusual stuff here. I suppose it's pos...   Mar 11 2020, 06:45 AM
rhodyguy   :agree: right. Small ball cup bushing, perhaps the...   Mar 11 2020, 06:58 AM
Mikey914   My money is on the pressure plate. I know I have r...   Mar 11 2020, 10:26 AM
sixnotfour   :wttc: Add Clutch Tube Broke Loose to the List......   Mar 11 2020, 10:52 AM
tinker_n_smoke   Started with looking at the clutch tube - suprisin...   Mar 11 2020, 01:05 PM
IronHillRestorations   First thing I would do is make sure you've got...   Mar 11 2020, 05:07 PM
DickSteinkamp   Not to send you chasing down another rabbit hol...   Mar 11 2020, 06:20 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:21 AM
