> newbie / clutch? HELP?, Not sure what to do here...
tinker_n_smoke
post Mar 8 2020, 08:09 PM
(IMG:style_emoticons/default/WTF.gif)
So I am a new 914 owner ( 1973) - car is running, but the clutch will not engage. Last owner said they thought the linkage was broken - but in looking under the car, the rod is moving just fine from shifter back to transmission.
As I am poking around today I notice this cable end out near the rear / firewall.
Is this my clutch cable? I think it is, but confused where the rest ended up.. and... where should I look/ repair for this?
THANK YOU!
tinker_n_smoke
post Mar 10 2020, 01:43 PM
link
Clip under car. looks like I am also missing the retaining clip..
ndfrigi
post Mar 10 2020, 01:53 PM
QUOTE(tinker_n_smoke @ Mar 10 2020, 11:43 AM) *
link
there you go! something wrong with your clutch pressure or more between tranny and engine.
tinker_n_smoke
post Mar 10 2020, 01:59 PM
QUOTE(ndfrigi @ Mar 10 2020, 02:53 PM) *
link
mrholland2
post Mar 10 2020, 04:01 PM
You should not be able to move that with your finger. It should have the full force of the clutch pressure plate springs against it. Either there is something broken mechanically or your pressure plate has no pressure at all. Or something similar, but it looks like some kind of replacement parts are needed in the clutch region.
QUOTE(tinker_n_smoke @ Mar 10 2020, 12:59 PM) *
link
tinker_n_smoke   newbie / clutch? HELP?   Mar 8 2020, 08:09 PM
DickSteinkamp   Won't engage or won't disengage?   Mar 8 2020, 09:18 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:51 PM
tinker_n_smoke   It will not engage. The movement on the stick / s...   Mar 8 2020, 09:52 PM
PanelBilly   That’s the cable for the heat   Mar 8 2020, 09:30 PM
tinker_n_smoke   thank you. good to know. That’s the cable for t...   Mar 8 2020, 09:52 PM
cuddy_k   :agree: That's one of the heater duct pull cab...   Mar 8 2020, 09:57 PM
Highland   I think that long grommet on your clutch cable (ag...   Mar 8 2020, 10:02 PM
Mikey914   The cable you should be looking at for the clutch ...   Mar 8 2020, 11:27 PM
Mikey914   You can have someone depress the clutch and it sho...   Mar 8 2020, 11:31 PM
DickSteinkamp   I'm still confused (as usual) You ENGAGE the ...   Mar 9 2020, 08:53 AM
Tbrown4x4   1. You push the clutch pedal down to disengage th...   Mar 9 2020, 09:31 AM
tinker_n_smoke   Thank you!! I tried best to explain below...   Mar 9 2020, 06:11 PM
tinker_n_smoke   OK, so I have looked at the pully/ clutch cable. W...   Mar 9 2020, 01:23 PM
tinker_n_smoke   grinding noise / video:: https://youtu.be/VP7bdVLE...   Mar 9 2020, 04:27 PM
ndfrigi   grinding noise / video:: https://youtu.be/VP7bdVL...   Mar 9 2020, 05:04 PM
JOEPROPER   Hard to tell what's going on there by the vide...   Mar 9 2020, 05:01 PM
tinker_n_smoke   appreciate the concerns for sure! I'm New...   Mar 9 2020, 06:05 PM
JOEPROPER   Are the wheels off the ground and is the car stabl...   Mar 9 2020, 05:03 PM
tinker_n_smoke   car is up / have the 4 wheels sitting on an old se...   Mar 9 2020, 06:02 PM
dr914@autoatlanta.com   call me tomorrow and I will guide you through it ...   Mar 9 2020, 05:43 PM
tinker_n_smoke   amazing! Thank you call me tomorrow and I w...   Mar 9 2020, 06:00 PM
tinker_n_smoke   Hi George - I got called in to work - will for sur...   Mar 11 2020, 02:37 PM
bbrock   I think the grinding is just because the clutch is...   Mar 9 2020, 06:01 PM
injunmort   check your shifter rod bushings and linkage alignm...   Mar 9 2020, 06:27 PM
tinker_n_smoke   link Clip under car. looks like I am also missing...   Mar 10 2020, 01:43 PM
ndfrigi   link Clip under car. looks like I am also missin...   Mar 10 2020, 01:53 PM
tinker_n_smoke   ? [quote name='tinker_n_smoke' post='2792975' da...   Mar 10 2020, 01:59 PM
mrholland2   You should not be able to move that with your fing...   Mar 10 2020, 04:01 PM
cuddy_k   Wow. Looks like you're missing some hardware. ...   Mar 10 2020, 05:08 PM
DickSteinkamp   I'm trying to figure out how you could shift i...   Mar 10 2020, 07:58 PM
tinker_n_smoke   I had the cable/assembly connected before, disconn...   Mar 10 2020, 08:47 PM
DickSteinkamp   I had the cable/assembly connected before, discon...   Mar 10 2020, 09:09 PM
rhodyguy   The wing nut is wrong. The blob behind it is weird...   Mar 10 2020, 09:28 PM
falcor75   Your pressure plate is toast or not there at all. ...   Mar 11 2020, 12:12 AM
Mikey914   Good news is it looks like a pressure plate issue ...   Mar 11 2020, 01:00 AM
Tbrown4x4   Lots of unusual stuff here. I suppose it's pos...   Mar 11 2020, 06:45 AM
rhodyguy   :agree: right. Small ball cup bushing, perhaps the...   Mar 11 2020, 06:58 AM
Mikey914   My money is on the pressure plate. I know I have r...   Mar 11 2020, 10:26 AM
sixnotfour   :wttc: Add Clutch Tube Broke Loose to the List......   Mar 11 2020, 10:52 AM
tinker_n_smoke   Started with looking at the clutch tube - suprisin...   Mar 11 2020, 01:05 PM
IronHillRestorations   First thing I would do is make sure you've got...   Mar 11 2020, 05:07 PM
DickSteinkamp   Not to send you chasing down another rabbit hol...   Mar 11 2020, 06:20 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:01 AM
