> Pressure plate wear., Causes.
914Toy
post Mar 19 2020, 08:21 AM
To the brain trust: re slight shudder when engaging the clutch in first gear to begin moving forward.
The clutch assembly is a Sachs brand 228 mm and was installed new about two years ago onto a new flywheel on my 2.7 911 engine, and now has some 5,000 street miles on it. Also new was the throw out bearing (Sachs) and nylon bush under the clutch fork.
I expected to see some clutch disk "burn" deposit on the fly wheel and/or pressure plate. To my surprise, while there were some small deposits on the flywheel and pressure plate, these parts and the clutch disk appear to be in near new condition - little measurable or obvious wear. However, the tips of the pressure plate "fingers (see pic) were worn down where the throw out bearing (TOB) contacts them. This suggests the TOB is slipping on the finger tips causing friction and wear. The TOB feels solid and spins freely like new.
I don't believe this is normal wear. Any thoughts/advice?
914Toy   Pressure plate wear.   Mar 19 2020, 08:21 AM
TravisNeff   I can't help with the reason for wear. I would...   Mar 19 2020, 08:32 AM
914Toy   I can't help with the reason for wear. I woul...   Mar 19 2020, 08:58 AM
TravisNeff   I did a little digging. https://forums.aussievee...   Mar 19 2020, 09:00 AM
914Toy   I did a little digging. https://forums.aussieve...   Mar 19 2020, 11:31 AM
SirAndy   This is the part that the throwout bearing is ridi...   Mar 19 2020, 10:09 AM
Root_Werks   This is the part that the throwout bearing is rid...   Mar 19 2020, 11:10 AM
dr914@autoatlanta.com   clutch cable too tight To the brain trust: re s...   Mar 19 2020, 12:22 PM
TravisNeff   OK, that is what I read elsewhere about bottoming ...   Mar 19 2020, 01:00 PM
914Toy   OK, that is what I read elsewhere about bottoming...   Mar 19 2020, 03:17 PM
porschetub   OK, that is what I read elsewhere about bottomin...   Mar 19 2020, 11:10 PM
porschetub   Wow that wear looks more like wear after 50,000 mi...   Mar 19 2020, 01:48 PM
TravisNeff   that distance washer goes on the outside of the fl...   Mar 19 2020, 03:28 PM
TravisNeff   From porsche pet for 74-77 911 Also found the thr...   Mar 19 2020, 03:30 PM
914Toy   From porsche pet for 74-77 911 Also found the th...   Mar 19 2020, 04:38 PM
GregAmy   That wear is between the pressure plate and the th...   Mar 19 2020, 04:46 PM
914Toy   That wear is between the pressure plate and the t...   Mar 19 2020, 08:49 PM
jcd914   To me the un-even wear on the pressure plate finge...   Mar 19 2020, 10:42 PM
sixnotfour   Aftermarket Flywheel...... :popcorn:   Mar 20 2020, 12:34 AM
914Toy   Thanks all. Hopefully a new TOB and pressure plate...   Mar 20 2020, 07:59 AM
Steve   Make sure you have a 1/2" free play at the pe...   Mar 20 2020, 08:12 AM
GregAmy   Another consideration is that the throwout bearing...   Mar 20 2020, 08:23 AM
TravisNeff   There is also the shim behind the ball for the cup...   Mar 20 2020, 09:26 AM
rgalla9146   Shudder at take off ? Possible bent throw-out fo...   Mar 20 2020, 01:11 PM
Mark Henry   Shudder at take off ? Possible bent throw-out f...   Mar 20 2020, 05:59 PM
wndsrfr   [quote name='rgalla9146' post='2795887' date='Mar...   Mar 20 2020, 08:29 PM
Mark Henry   [quote name='Mark Henry' post='2795960' date='Mar...   Mar 21 2020, 09:11 AM
Spoke   What does the wear on the TO bearing look like? If...   Mar 21 2020, 09:55 AM
rgalla9146   What does the wear on the TO bearing look like? I...   Mar 21 2020, 01:54 PM
914Toy   What does the wear on the TO bearing look like? ...   Mar 21 2020, 02:36 PM
roblav1   Looks typical of clutch cable too tight.   Mar 21 2020, 03:46 PM
914Toy   Completed installing the tranny with new pressure ...   Mar 27 2020, 02:38 PM
rgalla9146   Completed installing the tranny with new pressure...   Mar 27 2020, 03:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:56 PM
