> Quick oil pressure gauge wiring question
Tdskip
post Mar 25 2020, 06:05 AM
Good morning - hope everyone is going well.
I have an oil pressure gauge that looks like this one (not my car in picture but same sender),
1) I believe one terminal is for the actual pressure reading and one if for the warning light?
2) If that ^^^^ is correct does it matter which terminal is which? in other words is one terminal specific for the actual pressure reading?
Thanks!
Maltese Falcon
post Mar 25 2020, 08:22 AM
You can always give a call over to North Hollywood Speedometer (on Lankershim) and ask about the VDO terminals (unless marked). Small shop and are always cool with my questions !
Tdskip   Quick oil pressure gauge wiring question   Mar 25 2020, 06:05 AM
rgalla9146   Yes, it matters. One pole acts as a ground un...   Mar 25 2020, 07:04 AM
Tdskip   Yes, it matters. One pole acts as a ground u...   Mar 25 2020, 07:26 AM
IronHillRestorations   There's no wire in the 914 harness for an oil ...   Mar 25 2020, 07:37 AM
Tdskip   There's no wire in the 914 harness for an oil...   Mar 25 2020, 07:40 AM
ClayPerrine   There's no wire in the 914 harness for an oil...   Mar 25 2020, 12:50 PM
Maltese Falcon   You can always give a call over to North Hollywood...   Mar 25 2020, 08:22 AM
Tdskip   You can always give a call over to North Hollywoo...   Mar 25 2020, 08:34 AM
framos914   On same topic. I have the dual sender. My console...   Apr 18 2020, 06:04 PM
Tdskip   You are asking, just to be clear, about the oil pr...   Apr 18 2020, 08:50 PM
framos914   Yes, the oil pressure warning light. On the sender...   Apr 19 2020, 01:29 AM
rgalla9146   Yes, the oil pressure warning light. On the sende...   Apr 19 2020, 08:15 AM
framos914   Any chance you used teflon tape on the sender ? ...   Apr 19 2020, 11:53 AM
GregAmy   Those senders have two circuits: one variable for ...   Apr 19 2020, 08:15 AM
GregAmy   You can run a simple ground wire from the engine b...   Apr 19 2020, 12:11 PM
gereed75   I believe there are two different senders with two...   Apr 19 2020, 01:26 PM
framos914   Thanks Guys, it is a bad switched circuit on the...   Apr 20 2020, 05:54 PM
GregAmy   GregAmy: It is screwed directly into the case. ...   Apr 21 2020, 07:27 AM
- Lo-Fi Version Time is now: 16th June 2024 - 07:55 PM
