| Coondog |
Mar 25 2020, 05:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California
| slivel |
Mar 26 2020, 10:32 AM
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 553 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
My 3.4 liter engine has the Max Moritz pistons GE 80 cams, twin plug crank fired ignition and about 10.5 compression ratio. For reference it made 290 RWHP on the dyno with open exhaust but is probably down 30 or 40 HP with mufflers. Still a pretty exciting street ride. It will pull on my sons C-7 Grand Sport 2nd and 3rd gear and then he pulls away. He's got 460 HP but in 3200+ lbs car, mine weighs 2050 without me in it, so pretty good power to weight.
| Steve |
Mar 26 2020, 11:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,078 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
My 3.4 liter engine has the Max Moritz pistons GE 80 cams, twin plug crank fired ignition and about 10.5 compression ratio. For reference it made 290 RWHP on the dyno with open exhaust but is probably down 30 or 40 HP with mufflers. Still a pretty exciting street ride. It will pull on my sons C-7 Grand Sport 2nd and 3rd gear and then he pulls away. He's got 460 HP but in 3200+ lbs car, mine weighs 2050 without me in it, so pretty good power to weight. What are you guys running for intake? ITB, webers? |
| slivel |
Mar 26 2020, 12:10 PM
My 3.4 liter engine has the Max Moritz pistons GE 80 cams, twin plug crank fired ignition and about 10.5 compression ratio. For reference it made 290 RWHP on the dyno with open exhaust but is probably down 30 or 40 HP with mufflers. Still a pretty exciting street ride. It will pull on my sons C-7 Grand Sport 2nd and 3rd gear and then he pulls away. He's got 460 HP but in 3200+ lbs car, mine weighs 2050 without me in it, so pretty good power to weight. What are you guys running for intake? ITB, webers? I'm running Weber 46's that have had the The Paul Abbott treatment at Performance Oriented. With open exhaust it needed 185 mains to max the HP. With mufflers I'm experimenting with 165 or 170 mains to get best drivability. |
Coondog We don’t need no stinking badges Mar 25 2020, 05:12 PM
mepstein I already have the Max Moritz pistons, the larger ... Mar 25 2020, 05:34 PM
Coondog
I already have the Max Moritz pistons, the larger... Mar 25 2020, 05:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th September 2026 - 05:44 AM |
