> 3.2 to 3.4 Pros-Cons, Opinions/ Options
Coondog
post Mar 25 2020, 09:40 PM
Been thinking about this for a while as I am halfway there already. Don’t get me wrong 212 RWHP is nice but there always more on the table to be had and Steve’s 3.2 kicks my ass off the line every time..... (IMG:style_emoticons/default/blink.gif) It’s his 915 tranny.... (IMG:style_emoticons/default/driving.gif)
-964 cams already installed
-Big bore Throttle Body needed
-98mm piston and cylinders needed
-1 5/8" exhaust already installed
-Custom chip would have to get remapped. Not changing Motronic system and not going duel plug.
Opinions and options please.
live free & drive
post Mar 26 2020, 01:53 PM
Try Sal Carcellers fuel injection/chip mod with MAF. There is a lot to read up on Sal on Pelican beyond the link below too.
He can adjust the chip maps to your 964 cams, Ben's headers, and octane you want to run (also method of oil cooling).
http://forums.pelicanparts.com/porsche-911...stem-3-2-a.html
you might be looking at 250-260hp
I think the whole thing with custom tune cost ~$2K, probably cheaper than cracking open the case.
I also don't think he will help you if your engine is not running right until you get the basics sorted.
post Mar 26 2020, 02:02 PM
914-6 GT in waiting
QUOTE(live free & drive @ Mar 26 2020, 03:53 PM) *
Sal has a great system and If I stay motronic, I will buy it. It's ~$2K for his custom MAF, injectors, computer and chip but you still need dyno time to tune it. He sends you updated tune's as you work the engine on the dyno.
The last 5% always costs the most and there's a bit of irony because as you make more power from the engine, the 914 trans becomes more of an issue.
porschetub
post Mar 27 2020, 01:49 PM
QUOTE(mepstein @ Mar 27 2020, 09:02 AM) *
I had a MAF conversion on my 2.7 ROW 944 ,you could feel the extra 13hp increase just but the best thing was throttle response without the AFM restriction,the kit came with a cam advance key,custom MAF,DME chip adaptor and custom chip.
With the old DME ECU there is the issue with the boards failing Sal ups the game with rebuilt ecu and improved injectors.
I like the Motronic injection ,simple and easy to sort only issue I ever had was flywheel sensors which can give trouble,I think the OP should consider this system for his engine ,certainly cheaper the increasing displacement as mentioned.
- Lo-Fi Version Time is now: 20th October 2026 - 04:53 AM
