Springs, Shocks and Pegs, (well perhaps no Pegs) |
ctc911ctc |
Mar 30 2020, 07:57 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
OK,
I am a bit envious. Seems that many of you have figured out how to purchase springs and shocks for the rear of the 914. I have found myself going to different web sites being completely confused and as a result looking at all of you with envy. Shocks, Pegs......Lucky! The 914 rubber guys have 150lb springs, no shocks. Various sites have Bilstein's and then a few have an 'adjustable' gas shock called KYB. I found some 'racing' sites with 500lbs springs and then many options - mostly indecipherable. I need some couch time, here is what I am looking for. I have a mostly original '74 2.0 with a blown rear shock - that blown shock is original, which I am sure comes as no shock. The car seems to be a couple of inches lower than stock, I would like to have it ride a bit higher Other than that, original safe performance is all that I am seeking - What would you recommend? Spring LBS capability? Vendor? Approximate costs for estimates? Thank you! |
Olympic 914 |
Mar 31 2020, 07:57 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
I went with the setup from Ground Control.
https://groundcontrolstore.com/collections/...=19739474395232 Was looking for a good street ride, Not too stiff. So I ordered the 125# springs. Previously was running 914/6 rear springs with KYB shocks. I think they were 100# springs. (Two yellow dots) This setup handles great using the stock front torsion bars. and Bilstein front shocks. But I have not had it on the track. Eventually I may get Konis for the front also, but for now it works just fine. You can see a picture in my build thread at the bottom of my Sig, post #116 |
Lo-Fi Version | Time is now: 10th June 2024 - 11:57 AM |
