| Mueller |
Apr 2 2020, 12:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
So I understand there supposed to be some trimming of the rear pads on the bottom potion.
When I mock up the pad I've already milled on, it looks like I need to go another .100" to .125" more. Did I mess up the install? Top pad is modified, bottom stock. ![]() |
| twistedstang |
Apr 3 2020, 03:43 AM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
For all the guys that had to trim the pads....what rotor does Richs kit use on the back?
Mueller Boxster caliper install, do the rears need "that" much pad modifications? Apr 2 2020, 12:16 PM
twistedstang Hmmm. I used the Rebel Racing kit and didnt have t... Apr 2 2020, 02:32 PM
sixnotfour non S ?? Apr 2 2020, 03:17 PM
Mueller
non S ??
Yes, standard 986 calipers.
I am usin... Apr 2 2020, 04:56 PM
roblav1 I just went through this a couple weeks ago. Yes,... Apr 2 2020, 05:14 PM
Luke M Yes, the pads need to be trimmed at the bottom to ... Apr 2 2020, 06:24 PM
Mueller
Yes, the pads need to be trimmed at the bottom to... Apr 2 2020, 06:39 PM
jim_hoyland What did you use to modify the pads ?
http://www.... Apr 2 2020, 06:54 PM
Mueller Used my mill at home.
Apr 2 2020, 08:07 PM
jim_hoyland what if one doesn't have access to a mill ? Apr 2 2020, 08:49 PM
76-914
... Apr 2 2020, 09:23 PM
Mueller
... Apr 2 2020, 09:25 PM
twistedstang
... Apr 3 2020, 03:44 AM
roblav1 I did mine on a bench grinder. Just like I did on... Apr 2 2020, 10:26 PM
jd74914
I did mine on a bench grinder. Just like I did o... Apr 3 2020, 07:12 AM
Steve
For all the guys that had to trim the pads....wha... Apr 3 2020, 06:52 AM
sixnotfour
For all the guys that had to trim the pads....wha... Apr 3 2020, 08:56 AM
SirAndy For all the guys that had to trim the pads....what... Apr 3 2020, 09:33 AM
Mueller Can you run 15" wheels with the Rebel adapter... Apr 3 2020, 08:31 AM
twistedstang
Can you run 15" wheels with the Rebel adapte... Apr 3 2020, 08:44 AM
PotterPorsche The rebel racing kit does allow 15 inch rims Apr 3 2020, 09:04 AM
Th... Apr 3 2020, 09:33 AM
twistedstang
T... Apr 3 2020, 10:45 AM
Steve
[quote name='SirAndy' post='2800474' date='Apr 3 ... Apr 3 2020, 10:55 AM
Luke M
[quote name='twistedstang' post='2800506' date='A... Apr 3 2020, 11:15 AM
914forme Rebel kit fits the 911 parking brake as far as I c... Apr 3 2020, 11:47 AM
Steve
Rebel kit fits the 911 parking brake as far as I ... Apr 3 2020, 03:53 PM
lierofox Off topic, but I had to do a double-take while rea... Apr 3 2020, 12:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:03 PM |
