| Mueller |
Apr 2 2020, 12:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
So I understand there supposed to be some trimming of the rear pads on the bottom potion.
When I mock up the pad I've already milled on, it looks like I need to go another .100" to .125" more. Did I mess up the install? Top pad is modified, bottom stock. ![]() |
| Mueller |
Apr 3 2020, 08:31 AM
Can you run 15" wheels with the Rebel adapters?
That was the reason I went with the Johnson adapters since I knew they worked with 15" wheels. |
| twistedstang |
Apr 3 2020, 08:44 AM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
Mueller Boxster caliper install, do the rears need "that" much pad modifications? Apr 2 2020, 12:16 PM
twistedstang Hmmm. I used the Rebel Racing kit and didnt have t... Apr 2 2020, 02:32 PM
sixnotfour non S ?? Apr 2 2020, 03:17 PM
Mueller
non S ??
Yes, standard 986 calipers.
I am usin... Apr 2 2020, 04:56 PM
roblav1 I just went through this a couple weeks ago. Yes,... Apr 2 2020, 05:14 PM
Luke M Yes, the pads need to be trimmed at the bottom to ... Apr 2 2020, 06:24 PM
Mueller
Yes, the pads need to be trimmed at the bottom to... Apr 2 2020, 06:39 PM
jim_hoyland What did you use to modify the pads ?
http://www.... Apr 2 2020, 06:54 PM
Mueller Used my mill at home.
Apr 2 2020, 08:07 PM
jim_hoyland what if one doesn't have access to a mill ? Apr 2 2020, 08:49 PM
76-914
... Apr 2 2020, 09:23 PM
Mueller
... Apr 2 2020, 09:25 PM
twistedstang
... Apr 3 2020, 03:44 AM
roblav1 I did mine on a bench grinder. Just like I did on... Apr 2 2020, 10:26 PM
jd74914
I did mine on a bench grinder. Just like I did o... Apr 3 2020, 07:12 AM
twistedstang For all the guys that had to trim the pads....what... Apr 3 2020, 03:43 AM
Steve
For all the guys that had to trim the pads....wha... Apr 3 2020, 06:52 AM
sixnotfour
For all the guys that had to trim the pads....wha... Apr 3 2020, 08:56 AM
SirAndy For all the guys that had to trim the pads....what... Apr 3 2020, 09:33 AM
PotterPorsche The rebel racing kit does allow 15 inch rims Apr 3 2020, 09:04 AM
Th... Apr 3 2020, 09:33 AM
twistedstang
T... Apr 3 2020, 10:45 AM
Steve
[quote name='SirAndy' post='2800474' date='Apr 3 ... Apr 3 2020, 10:55 AM
Luke M
[quote name='twistedstang' post='2800506' date='A... Apr 3 2020, 11:15 AM
914forme Rebel kit fits the 911 parking brake as far as I c... Apr 3 2020, 11:47 AM
Steve
Rebel kit fits the 911 parking brake as far as I ... Apr 3 2020, 03:53 PM
lierofox Off topic, but I had to do a double-take while rea... Apr 3 2020, 12:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:29 PM |
