> Boxster caliper install, do the rears need "that" much pad modifications?, Rich Johnson adaptors , yes I tried to call him
Mueller
post Apr 2 2020, 12:16 PM
914 Freak!
So I understand there supposed to be some trimming of the rear pads on the bottom potion.
When I mock up the pad I've already milled on, it looks like I need to go another .100" to .125" more.
Did I mess up the install?
Top pad is modified, bottom stock.
PotterPorsche
post Apr 3 2020, 09:04 AM
The rebel racing kit does allow 15 inch rims
post Apr 3 2020, 09:33 AM
Resident German
QUOTE(PotterPorsche @ Apr 3 2020, 08:04 AM) *
They all fit 15" wheels, the trimming is needed on the inside, not the outside.
twistedstang
post Apr 3 2020, 10:45 AM
QUOTE(SirAndy @ Apr 3 2020, 11:33 AM) *
Correct, but the Rebel kit is designed to use boxster rotors in back which push everything out a little
Mueller   Boxster caliper install, do the rears need "that" much pad modifications?   Apr 2 2020, 12:16 PM
twistedstang   Hmmm. I used the Rebel Racing kit and didnt have t...   Apr 2 2020, 02:32 PM
sixnotfour   non S ??   Apr 2 2020, 03:17 PM
Mueller   non S ?? Yes, standard 986 calipers. I am usin...   Apr 2 2020, 04:56 PM
roblav1   I just went through this a couple weeks ago. Yes,...   Apr 2 2020, 05:14 PM
Luke M   Yes, the pads need to be trimmed at the bottom to ...   Apr 2 2020, 06:24 PM
Mueller   Yes, the pads need to be trimmed at the bottom to...   Apr 2 2020, 06:39 PM
jim_hoyland   What did you use to modify the pads ? http://www....   Apr 2 2020, 06:54 PM
Mueller   Used my mill at home.   Apr 2 2020, 08:07 PM
jim_hoyland   what if one doesn't have access to a mill ?   Apr 2 2020, 08:49 PM
76-914   what if one doesn't have access to a mill ? ...   Apr 2 2020, 09:23 PM
Mueller   what if one doesn't have access to a mill ? ...   Apr 2 2020, 09:25 PM
twistedstang   what if one doesn't have access to a mill ? ...   Apr 3 2020, 03:44 AM
roblav1   I did mine on a bench grinder. Just like I did on...   Apr 2 2020, 10:26 PM
jd74914   I did mine on a bench grinder. Just like I did o...   Apr 3 2020, 07:12 AM
twistedstang   For all the guys that had to trim the pads....what...   Apr 3 2020, 03:43 AM
Steve   For all the guys that had to trim the pads....wha...   Apr 3 2020, 06:52 AM
sixnotfour   For all the guys that had to trim the pads....wha...   Apr 3 2020, 08:56 AM
SirAndy   For all the guys that had to trim the pads....what...   Apr 3 2020, 09:33 AM
Mueller   Can you run 15" wheels with the Rebel adapter...   Apr 3 2020, 08:31 AM
twistedstang   Can you run 15" wheels with the Rebel adapte...   Apr 3 2020, 08:44 AM
PotterPorsche   The rebel racing kit does allow 15 inch rims   Apr 3 2020, 09:04 AM
SirAndy   The rebel racing kit does allow 15 inch rims Th...   Apr 3 2020, 09:33 AM
twistedstang   The rebel racing kit does allow 15 inch rims T...   Apr 3 2020, 10:45 AM
Steve   [quote name='SirAndy' post='2800474' date='Apr 3 ...   Apr 3 2020, 10:55 AM
Luke M   [quote name='twistedstang' post='2800506' date='A...   Apr 3 2020, 11:15 AM
914forme   Rebel kit fits the 911 parking brake as far as I c...   Apr 3 2020, 11:47 AM
Steve   Rebel kit fits the 911 parking brake as far as I ...   Apr 3 2020, 03:53 PM
lierofox   Off topic, but I had to do a double-take while rea...   Apr 3 2020, 12:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:30 PM
