| Mueller |
Apr 2 2020, 12:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
So I understand there supposed to be some trimming of the rear pads on the bottom potion.
When I mock up the pad I've already milled on, it looks like I need to go another .100" to .125" more. Did I mess up the install? Top pad is modified, bottom stock. ![]() |
| PotterPorsche |
Apr 3 2020, 09:04 AM
Member ![]() ![]() Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
The rebel racing kit does allow 15 inch rims
| SirAndy |
Apr 3 2020, 09:33 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The rebel racing kit does allow 15 inch rims They all fit 15" wheels, the trimming is needed on the inside, not the outside. (IMG:style_emoticons/default/shades.gif) |
| twistedstang |
Apr 3 2020, 10:45 AM
Member ![]() ![]() Group: Members Posts: 229 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None
The rebel racing kit does allow 15 inch rims They all fit 15" wheels, the trimming is needed on the inside, not the outside. (IMG:style_emoticons/default/shades.gif) Correct, but the Rebel kit is designed to use boxster rotors in back which push everything out a little |
| Steve |
Apr 3 2020, 10:55 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
The rebel racing kit does allow 15 inch rims They all fit 15" wheels, the trimming is needed on the inside, not the outside. (IMG:style_emoticons/default/shades.gif) Correct, but the Rebel kit is designed to use boxster rotors in back which push everything out a little (I beleive) Curious what rotors rebel racing works with and if they also support the 911 parking brake? |
Mueller Boxster caliper install, do the rears need "that" much pad modifications? Apr 2 2020, 12:16 PM
twistedstang Hmmm. I used the Rebel Racing kit and didnt have t... Apr 2 2020, 02:32 PM
sixnotfour non S ?? Apr 2 2020, 03:17 PM
Mueller
non S ??
Yes, standard 986 calipers.
I am usin... Apr 2 2020, 04:56 PM
roblav1 I just went through this a couple weeks ago. Yes,... Apr 2 2020, 05:14 PM
Luke M Yes, the pads need to be trimmed at the bottom to ... Apr 2 2020, 06:24 PM
Mueller
Yes, the pads need to be trimmed at the bottom to... Apr 2 2020, 06:39 PM
jim_hoyland What did you use to modify the pads ?
http://www.... Apr 2 2020, 06:54 PM
Mueller Used my mill at home.
Apr 2 2020, 08:07 PM
jim_hoyland what if one doesn't have access to a mill ? Apr 2 2020, 08:49 PM
76-914
... Apr 2 2020, 09:23 PM
Mueller
... Apr 2 2020, 09:25 PM
twistedstang
... Apr 3 2020, 03:44 AM
roblav1 I did mine on a bench grinder. Just like I did on... Apr 2 2020, 10:26 PM
jd74914
I did mine on a bench grinder. Just like I did o... Apr 3 2020, 07:12 AM
twistedstang For all the guys that had to trim the pads....what... Apr 3 2020, 03:43 AM
Steve
For all the guys that had to trim the pads....wha... Apr 3 2020, 06:52 AM
sixnotfour
For all the guys that had to trim the pads....wha... Apr 3 2020, 08:56 AM
SirAndy For all the guys that had to trim the pads....what... Apr 3 2020, 09:33 AM
Mueller Can you run 15" wheels with the Rebel adapter... Apr 3 2020, 08:31 AM
twistedstang
Can you run 15" wheels with the Rebel adapte... Apr 3 2020, 08:44 AM
Luke M
[quote name='twistedstang' post='2800506' date='A... Apr 3 2020, 11:15 AM
914forme Rebel kit fits the 911 parking brake as far as I c... Apr 3 2020, 11:47 AM
Steve
Rebel kit fits the 911 parking brake as far as I ... Apr 3 2020, 03:53 PM
lierofox Off topic, but I had to do a double-take while rea... Apr 3 2020, 12:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:29 PM |
