> Boxster caliper install, do the rears need "that" much pad modifications?, Rich Johnson adaptors , yes I tried to call him
Mueller
post Apr 2 2020, 12:16 PM
914 Freak!
So I understand there supposed to be some trimming of the rear pads on the bottom potion.
When I mock up the pad I've already milled on, it looks like I need to go another .100" to .125" more.
Did I mess up the install?
Top pad is modified, bottom stock.
914forme
post Apr 3 2020, 11:47 AM
Rebel kit fits the 911 parking brake as far as I can tell during mockup. I never got the opportunity to test under load. YMMV
Steve
post Apr 3 2020, 03:53 PM
QUOTE(914forme @ Apr 3 2020, 10:47 AM) *
Were you using a Boxster rotor with the 911 parking brake?
Otherwise its no big deal to trim the pad for the 911 disk.
Mueller   Boxster caliper install, do the rears need "that" much pad modifications?   Apr 2 2020, 12:16 PM
twistedstang   Hmmm. I used the Rebel Racing kit and didnt have t...   Apr 2 2020, 02:32 PM
sixnotfour   non S ??   Apr 2 2020, 03:17 PM
Mueller   non S ?? Yes, standard 986 calipers. I am usin...   Apr 2 2020, 04:56 PM
roblav1   I just went through this a couple weeks ago. Yes,...   Apr 2 2020, 05:14 PM
Luke M   Yes, the pads need to be trimmed at the bottom to ...   Apr 2 2020, 06:24 PM
Mueller   Yes, the pads need to be trimmed at the bottom to...   Apr 2 2020, 06:39 PM
jim_hoyland   What did you use to modify the pads ? http://www....   Apr 2 2020, 06:54 PM
Mueller   Used my mill at home.   Apr 2 2020, 08:07 PM
jim_hoyland   what if one doesn't have access to a mill ?   Apr 2 2020, 08:49 PM
76-914   what if one doesn't have access to a mill ? ...   Apr 2 2020, 09:23 PM
Mueller   what if one doesn't have access to a mill ? ...   Apr 2 2020, 09:25 PM
twistedstang   what if one doesn't have access to a mill ? ...   Apr 3 2020, 03:44 AM
roblav1   I did mine on a bench grinder. Just like I did on...   Apr 2 2020, 10:26 PM
jd74914   I did mine on a bench grinder. Just like I did o...   Apr 3 2020, 07:12 AM
twistedstang   For all the guys that had to trim the pads....what...   Apr 3 2020, 03:43 AM
Steve   For all the guys that had to trim the pads....wha...   Apr 3 2020, 06:52 AM
sixnotfour   For all the guys that had to trim the pads....wha...   Apr 3 2020, 08:56 AM
SirAndy   For all the guys that had to trim the pads....what...   Apr 3 2020, 09:33 AM
Mueller   Can you run 15" wheels with the Rebel adapter...   Apr 3 2020, 08:31 AM
twistedstang   Can you run 15" wheels with the Rebel adapte...   Apr 3 2020, 08:44 AM
PotterPorsche   The rebel racing kit does allow 15 inch rims   Apr 3 2020, 09:04 AM
SirAndy   The rebel racing kit does allow 15 inch rims Th...   Apr 3 2020, 09:33 AM
twistedstang   The rebel racing kit does allow 15 inch rims T...   Apr 3 2020, 10:45 AM
Steve   [quote name='SirAndy' post='2800474' date='Apr 3 ...   Apr 3 2020, 10:55 AM
Luke M   [quote name='twistedstang' post='2800506' date='A...   Apr 3 2020, 11:15 AM
914forme   Rebel kit fits the 911 parking brake as far as I c...   Apr 3 2020, 11:47 AM
Steve   Rebel kit fits the 911 parking brake as far as I ...   Apr 3 2020, 03:53 PM
lierofox   Off topic, but I had to do a double-take while rea...   Apr 3 2020, 12:01 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:05 PM
