adventures in suspension, I took some measurements... |
914 RZ-1 |
Mar 30 2020, 08:16 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I was on a drive with some other folks on Sunday (don't worry; we all kept 6 feet apart) and the guy behind me tells me that when I turn hard right the car leans more than when I turn hard left. Looks like the springs/shocks/suspension needs some attention. Where do I begin?
I have never replaced or adjusted any of the suspension on this car. For replacement parts (if I need them), what are good shocks and springs and where is a good place to get them? I'm not looking for anything fancy; the "stock" ride is fine. Are there any techniques or fancy tools I should know about? Thanks! |
ndfrigi |
Apr 4 2020, 10:40 PM
Advanced Member Group: Members Posts: 2,929 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
For sure you can replace the rear shocks in an hour or Two as long you have spring compresser. Not really hard. And if the shocks is bad, after removal from the spring, you will notice the shock will not go up after pushing it in. Front a little tricky when you remove the insert from the strut but doable for 1 man job also.
Front height adjustment just a bolt one each side. |
Lo-Fi Version | Time is now: 23rd May 2024 - 03:08 PM |
